Guest Blars Posted March 6, 2017 Share Posted March 6, 2017 I'm having an issue with VW selecting whole objects from components of thet object that are not visible. For example, I am attempting to select a line drawn at a wall by selecting the line thats visible at the door. VW keeps selecting the door rather than the line even though the door head is not visible. How can i make VW select only whats visible? Thanks. Quote Link to comment
AlanW Posted March 6, 2017 Share Posted March 6, 2017 (edited) @BlarsHi, if you hold down the J key on the keyboard and then select the line you should get a dialogue box giving you the door and line select the appropriate one and it deselects the other. HTH Edited March 6, 2017 by Alan Woodwell Quote Link to comment
Guest Blars Posted March 6, 2017 Share Posted March 6, 2017 Unfortunately "J" is a defined command on my setup. What is the tool or menu item so i can customize my interface to cycle through overlapping items? Thanks. Quote Link to comment
AlanW Posted March 7, 2017 Share Posted March 7, 2017 @BlarsRemap the key, standard is as attached. HTH Quote Link to comment
Guest Blars Posted March 9, 2017 Share Posted March 9, 2017 Excellent. Thank you! Quote Link to comment
