I have created a document that uses Text Along Path, to have the text wrap around this edge of a circle. This all looks good. I have changed the text a few times with no issues. However, now, when I try to change the wording I RightClick on the text and choose Edit Profile I get the edit window BUT the text appears only for a half second then disappears totally - BUT the Object info palette goes blank! ... I have Show/Snap/Modify Others turned on for classes and layers, so I don't think it is a visibility issue.
Now, one thing it MIGHT be is that I have copied and pasted this Text Along Path object... could it not like to work on copies? I don't think that could be it because it HAS worked with some copies before. If I recreate the file from scratch it works and will work on copies but at some point along the way it just stops allowing me to edit this text
Meschter
Hi all -
What am I missing?
Thanks in advance for your help,
Dave
I am using VW2017, Spotlight on PC in Windows10
2 answers to this question
