kklik
Viewport creation issues
Hi,
I'm having a problem creating viewports on a sheet layer that appears intermittently.
On the sheet layer I create a bounding box around the objects I want to show (top plan view) and hit "create Viewport" in the View drop down menu. The normal dialog appears and when I hit OK without changing anything I get a message saying " That viewport is already being used by another object. Please use a different name".
Starting again and changing the name in the Create Viewport pane brings up the same error message.
I can create the same viewport, without changing the name in the dialogue box, on a different sheet layer and then send it to my required sheet layer without any problems.
Not a big problem but it messes up the workflow.
Any thoughts would be appreciated
Regards
Knut
6 answers to this question
Sorry I'm kinda dumb with VW, but when you say you created a bounding box, did you use the rectangle tool or is there another tool hide somewhere? Are you trying to create a viewport over another viewport? I tried with the rectangle tool but received an entirely different message.  I have to start with View>create viewport, then set up a crop for the viewport.
On 3/3/2017 at 2:27 AM, kklik said:
Hi,
Regards
Knut
Do you have a class, layer or any symbols or other resources named exactly "Viewport" anywhere in your file?
Same issue here. I have a class with the same name as the viewport I am attempting to create and it is telling me " the viewport name is already being used by another object." Seems odd that a class and viewport couldn't share the same name as they are two entirely different things.
Correct, no two things in Vectorworks can be named the same string of text. This will change in the future, but for now there is no avoiding it.
