Josh NZ Posted March 1, 2017 Share Posted March 1, 2017 The below image is from a new blank file and shows 3 "spaces". Anyone see the issue when using them to show room sizes? Hopefully the same issue doesn't happen for windows, columns and other objects. Quote Link to comment
Pat Stanford Posted March 1, 2017 Share Posted March 1, 2017 Is it just an issue of how the label is created? Can you change the order the fields to match what you want? For me, the "Height" field in the Space Object Record is Length. The "Width" field in the Space Object Record is "Width" Put them in the order you want and them put the other text you want around them. Quote Link to comment
Josh NZ Posted March 1, 2017 Author Share Posted March 1, 2017 We would be happy with either width by height, or height by width. At the moment its just larger dimension by smaller dimension. In the settings you can only pick "calculate room dimensions". Quote Link to comment
Pat Stanford Posted March 1, 2017 Share Posted March 1, 2017 I see options in the Format Field for Length and Width in addition to Calculate Room Dim. If you click the Manage Space Labels you can add as many field to the label as you need. If you click the Edit Layout button you can move the text blocks around to get the arrangement you want. If you click the Edit button to the right of the Format Field you can add prefix and suffixes as necessary to each field. Let me know if this is not clear and I can send pictures. Quote Link to comment
Rishie Posted August 9, 2018 Share Posted August 9, 2018 Could we calculate (X direction x Y direction) ? other then (length x width) (or) (width x length), calculate room dimension taken as (length x width) which is longer side of rectangle x shorter side of rectangle Quote Link to comment
Mark Aceto Posted October 12, 2020 Share Posted October 12, 2020 (edited) @Pat Stanford I'm confused about editing Data Tags from within Space Tool Settings. I simply want to duplicate the "Space Tag-Simple w/ Area" tag, and then add calculated room dim's, ceiling height, and volume. Edited October 12, 2020 by Mark Aceto Quote Link to comment
Mark Aceto Posted October 13, 2020 Share Posted October 13, 2020 (edited) On 3/1/2017 at 10:50 AM, Pat Stanford said: I see options in the Format Field for Length and Width in addition to Calculate Room Dim. If you click the Manage Space Labels you can add as many field to the label as you need. If you click the Edit Layout button you can move the text blocks around to get the arrangement you want. If you click the Edit button to the right of the Format Field you can add prefix and suffixes as necessary to each field. Let me know if this is not clear and I can send pictures. I'm getting the same issue with a Data Tag (I gave up on the Space Label). The issue seems to be there's no correlation with X or Y: "length" = longest dim "width" = shortest dim I need to find a way to: Display "X length x Y length" Show secondary units (metric) for volume Show thousands separators Edited October 13, 2020 by Mark Aceto Quote Link to comment
Mark Aceto Posted October 13, 2020 Share Posted October 13, 2020 (edited) @Pat Stanford Also, how is the Edit Data Tag window organized, so that I can display all of the fields in the same order as the tag display vs this: Edited October 13, 2020 by Mark Aceto Quote Link to comment
BizGoz Posted February 1, 2023 Share Posted February 1, 2023 Hello all, I'm running into the same issue. Even though I've adjusted the text in my space tags, the widths & lengths are not displaying properly. At some point as the boundary increases, the dimensions mislabel the width/length. Has anyone found a way to resolve this? Quote Link to comment
BizGoz Posted February 2, 2023 Share Posted February 2, 2023 My workaround was to create two space tags, width X height & height X width to use as needed Quote Link to comment
Silvano Posted February 5, 2023 Share Posted February 5, 2023 (edited) Em 01/02/2023 em 17:17, BizGoz disse: Hello all, I'm running into the same issue. Even though I've adjusted the text in my space tags, the widths & lengths are not displaying properly. At some point as the boundary increases, the dimensions mislabel the width/length. Has anyone found a way to resolve this? I had this same problem in the space object, which was solved with "calculate room dimensions". Em 01/02/2023 em 17:17, BizGoz disse: Hello all, I'm running into the same issue. Even though I've adjusted the text in my space tags, the widths & lengths are not displaying properly. At some point as the boundary increases, the dimensions mislabel the width/length. Has anyone found a way to resolve this? I had this same problem in the space object, which was solved with "calculate room dimensions". Edited February 5, 2023 by Silvano Duplicate Quote Link to comment
BizGoz Posted February 6, 2023 Share Posted February 6, 2023 @Silvano can you elaborate? I have "calculate room dimensions" selected but doesn't fix the issue. I might be missing something. Thanks Quote Link to comment
Silvano Posted February 10, 2023 Share Posted February 10, 2023 BizGoz, it's just and exactly what you did in the last post. I don't understand why it didn't work for you or why I needed to do it, but it worked for me. Quote Link to comment
