I am attempting to create a curved built-in bookshelf using extrude along path. I created the profile as a 2d polygon and am using a polyline converted to a 3d polygon in order to gain a z parameter, as the path.
This is a fairly simple path and profile, yet it takes upwards of 30 minutes to generate, all the while vectorworks is frozen and I get a spinning beach ball. Luckily I am able to use other applications on my computer as normal, but vectorworks is reported as "application not responding" until the process is complete.
Once the EAP operation is complete, the file is still very laggy in both 2d and 3d views. In an attempt to make the file less laggy, I converted the EAP object to a group of 3d polygons and simplified them by 1 inch, but this results in very weird texture rendering unlike the EAP solid. This does almost completely eliminate the lag associated with the EAP
In the file attached, the path and profile objects are on the Extrude Primitives layer, the extrude test layer contains the completed extrude, and the polygons layer contains the grouped 3d polygons generated from converting the EAP object.
EDIT: I know that my hardware specs are not the greatest, but vectorworks runs fine except for this issue as long as I don't try and do crazy OpenGL or renderworks fanciness.
EDIT 2: I realized I forgot to upload the file and attach it, and in the process I realized that it is 236Mb. This would potentially explain why it is so laggy, but why would an EAP object, 2 polygons and the extracted group of polygons be over 200Mb. My other file that I was originally trying this in is only around 155Mb and contains loads more geometry and PIOs.
Hello:
Dropbox link to file: https://www.dropbox.com/s/izc6u2d5m4koqob/extrude-test.vwx?dl=0
Thanks in advance.
Edited by sww1235Attaching file
