Bryan_dup1 Posted December 12, 2003 Share Posted December 12, 2003 I've just purchased my first laptop and miss the quick change view abilities of using the key pad on a full size keyboard. What is the work around be on a laptop? How do the rest of you deal with this without using the pull down menu? I don't want to carry and use an external keypad/keyboard. Thanks for any input. Quote Link to comment
Richard Anderson Posted December 12, 2003 Share Posted December 12, 2003 I'm still puzzled about what it is you need but it sounds like you have things under control. As an extra, I recently changed the default "redo" key command to the somewhat standard "cmd-shift-Z". By default, this brings up the plug-in creator dialogue. I assigend the new command in the system pref's and changed the assignment in Vectorworks. (The new "redo"short-cut takes effect only after logging out and in again.) Quote Link to comment
Bryan_dup1 Posted December 12, 2003 Author Share Posted December 12, 2003 I change from top, front, side, and 4 iso views when drawing and have the habit of changing those views on the keyboard. My laptop doesn't have the 0 thru 9 keypad to which these views are assigned by default. Quote Link to comment
propstuff Posted December 12, 2003 Share Posted December 12, 2003 Hi Bryan, on my TiBk the keypad is "under" keys uio,jkl&m. The are accessed by holding down the "fn" key (bottom left) and work as normal. ps I hate the nasty keyboards on laptops and always use an external when not away :-) cheers, N. Quote Link to comment
Bryan_dup1 Posted December 12, 2003 Author Share Posted December 12, 2003 Thanks Nicholas, I just received my Powerbook on Monday and hadn't noticed the FN key there until you pointed it out. [ 12-12-2003, 04:51 PM: Message edited by: Bryan ] Quote Link to comment
Richard Anderson Posted December 13, 2003 Share Posted December 13, 2003 WHich size P-book are you using Bryan? And which key commands have you found yourself missing? I ask because I go from desktop to 15" TiBook often and it takes a bit for the new spatial recognition in my fingers to sink in. Quote Link to comment
Bryan_dup1 Posted December 13, 2003 Author Share Posted December 13, 2003 Thanks Richard, I have the 12" with a 17" external Apple Display. Quote Link to comment
Guest Posted December 13, 2003 Share Posted December 13, 2003 You will need to use the workspace editor and set keyboard shortcuts for the views. Top Plan has a shortcut already assigned, but can be changed. Quote Link to comment
Bryan_dup1 Posted December 13, 2003 Author Share Posted December 13, 2003 Thanks Richard & Katie, Now I just have to find open key combinations or change some. Quote Link to comment
