2016 SP4 Line tool won't stay in one spot - origin moves around screen
Hobbsies
See video for description. I'm using the line to in vertex mode and the origin will not stay put. It's inconsistent, sometimes the line works fine and other times the line behaves as if it's rotating around a giant invisible circle in some sort of tangent mode. I've restarted vectorworks multiple times and this occurs in a variety of different files. This started when I upgraded to SP4 a few months ago.
What's the solution?
5 answers to this question
Likely there is something on another layer that the snap is picking up but you aren't seeing, if it comes back even though you have tangent snapping off, Unified View should align all the layers and in the Unified View options, you can disable hiding objects on layers with different scales which might reveal what it's trying to snap to as well.
