Symbol Names in DWG Export
Gottcha. Ok, you're not really exporting symbols in this instance rather Lighting Instruments that use a hybrid symbol as their graphic object.
The numbers are not random, they are the internally assigned VW number for each instrument.
In a duplicate file: Select all the lighting, Modify>Convert>Convert to Group.
This will extract the Symbols. Now if you perform the export the DWG you will get the named Symbols in place as expected.
