joerg
text rendreing issue
i got the problem that text (in 3D plane) does not render correctly in open GL anymore (in viewport) this is new since i upgraded to VW2017...any solution?
openGL_issue.vwx
0
Share on other sites
10 answers to this question
i just exported to VW 2016 and opened it with VW 2016 and it works perfectly so...did i pay for an update and got worse results on my usual workflow and new function i never use??
0
@joergHi, opened your file and I didn't have the font so it substituted one. Rendered correctly. I recall that Mac and VW may have issues with a few fonts, Jim mentioned it the other day. Try another regular font from the VW library and see if you get the same issue,
0
Also, go to Tools > Options > Vectorworks Preferences > Display > Edit Font Mappings on both your 2016 and 2017 licenses and make sure they are mapped the same way, this sometimes doesn't migrate properly between versions with some font types.
0
After switching to Arial, if I create a new viewport, it works fine, but the old converted viewports still do not display the text properly. If recreating the viewports after selecting a supported font works in your document let me know, otherwise make sure to get in touch directly with technical support and have them take a look. If they can confirm this as a conversion issue it can be filed as a bug.
0
thank all together...! .i made a new Viewport didn't work here still same bad result.... i installed the font recently so it might not connect to fontmapping and it is a file i created in VW2017( on a converted template) ill try on an empty file and if its working than recreate the tamplates otherways  i might tell tech support
0
i tryed it but  it has to do with openGL left viewport is wireframe right VP is openGL ill submit a bug than...
actually if i make the VP and set renderstyle to OpenGL while creating it shows ok but as soon as i change the dpi of the viewport it looks like this...
Edited by joerg
0
i did this by purpose to keep the filesize down but no it doesn't get better....
0
