How to set Parameter Visibilities in OIP
I'm trying to set parameter visibility in the object info panel.
In the old vector script I would retrieve the custom object information as follows:
result:= GetCustomObjectInfo(objname,oh,rh,wh);
I would then set the visibility of the parameter as follows:
SetParameterVisibility(oh,'parametername',FALSE);
In python I am trying to accomplish the same thing.
I've tried the following:
result = vs.GetCustomObjectInfo(objname,oh,rh,wh)
and then I attempted to set the visibility as follows:
vs.SetParameterVisibility(oh, 'parametername', FALSE)
when i run the script I get the following error:
NameError:  name 'objname' is not defined
Does anyone know how to accomplish this using best practice?
Thanks,
Derek
I have not assigned a value to objname.  I've created a plugin object and I need to reference and object handle to set the visibilities of the parameter.  how do i acquire or assign these?
I thought using the following:
would have acquired and assigned these for me
Edited by MaxStudio
I've eliminated the vs.GetCustomObjectInfo(objname,oh,rh,wh) and just used vs.SetParameterVisibility(handle, 'parametername', FALSE)
I set the object handle to zero
vs.SetParameterVisibility(0, 'parametername', FALSE)
I want to use a pulldown to set the visibility to true:
number=vs.Pnumber
if number == "2":
    vs.SetParameterVisibility(0, 'parametername', True )
but I'm getting the following error:
Error: Invalid callback function parameter type. Parameter index= 0 name=inPlugin
     File "<string>", line 38, in <module>
     File "<string>", line 1, in <module>
below is the actual code:
import vs
import shapes
number=vs.Pnumber
shape01=vs.Pshape01
shape02=vs.Pshape02
shape03=vs.Pshape03
xstart=0
vs.SetParameterVisibility(0, 'shape01', False )
vs.SetParameterVisibility(0, 'shape02', False )
vs.SetParameterVisibility(0, 'shape03', False )
if number == "2":
    vs.SetParameterVisibility(0, 'shape01', True )
    vs.SetParameterVisibility(0, 'shape02', True )
if number == "3":
    vs.SetParameterVisibility(0, 'shape03', True )
Derek,
I should have read the documentation before I asked my question. 'objname' is returned by the function vs.GetCustomObjectInfo().
However, in Python, all returned variables must be to the left of the equal sign. Try this:
result, objname, oh, rh, wh = vs.GetCustomObjectInfo()
then use the handle "oh" in your vs.SetParameterVisibility() calls.
Raymond
