rebu1985 Posted February 16, 2017 Share Posted February 16, 2017 Hi guys, I have found in the forum a topic which i would like to know because it would be really useful for me. You can find below: Copy object(s) to Paste (this step is performed pre vs execution) Execute vs 1. VS Brings up a dialog window with available design and sheet layers 2. User selects layer(s) on to which the object(s) to be pasted in place 3. Click "OK" 4. Layer visibility set to "Active Only", the script activates each selected layer in turn and pastes in place initially copied object(s) The purpose of this script its to have some objects (stairs, lifts, structure,etc) of a building keep in the same position in different design layers (they work as floor levels). Laura 1 Quote Link to comment
zoomer Posted February 16, 2017 Share Posted February 16, 2017 Automatically paste (in place of course !) copied selections into more than one Layer would be really nice ! Quote Link to comment
bcd Posted February 16, 2017 Share Posted February 16, 2017 Bounded stairs can be displayed automatically in both the lower and upper Layer in 2d. In 3d the Layer the stair will be visible whenever its layer is visible. This functionality could/ought to be expanded to include elevators, arguably one Elevator object that is visible on all selected Story layers. Quote Link to comment
MullinRJ Posted February 16, 2017 Share Posted February 16, 2017 Writing the dialog code will be the harder part of this task. To paste on multiple layers just requires a simple loop where the layer name can be accessed each time, and you won't need to copy before running the script, the script can do it for you. Just select your objects and run your script. The code will look something like this: BEGIN << Dialog code to select multiple layers and save in an array >> if not DidCancel then begin DoMenuTextByName('Copy', 0); { copy selected objects to paste } for I := 1 to NumSelectedLayers do begin Layer(LayerNameArray[I]); { change active layer for pasting } DoMenuTextByName('Paste In Place', 0); end; { for } end; { if } END; Quote Link to comment
rebu1985 Posted February 17, 2017 Author Share Posted February 17, 2017 (edited) Hi guys, I have been working on the script and i have done this one. The script is still wrong and I dont know the answer. Could you help me guys, please? PROCEDURE CreateDialog; VAR h: HANDLE; nl,i,a: INTEGER; layer : STRING; dupl,go,ok : BOOLEAN; Layers: DYNARRAY OF STRING; FUNCTION result : INTEGER; VAR id : INTEGER; BEGIN id := CreateLayout('Revise Layer Link',TRUE,'ok', 'Cancel'); CreateStaticText(id,4,'Layers:',-1); CreatePulldownMenu(id,5,32); CreateCheckBox(dialogID,30,'Follow objects'); CreateCheckBox(id,40,'duplicate objects'); CreateGroupBox(id,6,'Layers Options',TRUE); CreateCheckBox(id,7,'Planta Sótano'); CreateCheckBox(id,8,'Planta Baja'); CreateCheckBox(id,9,'Planta 1'); CreateCheckBox(id,10,'Planta 2'); CreateCheckBox(id,11,'Planta 3'); CreateCheckBox(id,12,'Planta 4'); CreateCheckBox(id,13,'Planta 5'); CreateCheckBox(id,14,'Planta 6'); CreateCheckBox(id,15,'Planta 7'); CreateCheckBox(id,16,'Planta 8'); CreateCheckBox(id,17,'Planta Atico'); CreateCheckBox(id,18,'Planta Cubierta'); SetFirstLayoutItem(id, 4); SetBelowItem (id,4,6,0,0); SetFirstGroupItem(id,6,7); SetBelowItem (id,7,8,0,0); SetBelowItem (id,8,9,0,0); SetBelowItem (id,9,10,0,0); SetBelowItem (id,10,11,0,0); SetBelowItem (id,11,12,0,0); SetBelowItem (id,12,13,0,0); SetBelowItem (id,13,14,0,0); SetBelowItem (id,14,15,0,0); SetBelowItem (id,15,16,0,0); SetBelowItem (id,16,17,0,0); SetBelowItem (id,17,18,0,0); SetBelowItem(id,18,30,0,0); SetBelowItem(id,30,40,0,0); SetHelpString(a,'Select a layer to transfer your selected object'); SetHelpString(30,'Go to the selected option with the actual visibility settings'); SetHelpString(40,'Select to duplicate your selected object'); result := RunLayoutDialog(id,NIL) END; Procedure GetLayers; BEGIN nl:= NumLayers; ALLOCATE Layers[1..nl]; h:=FLayer; For i:=1 TO nl DO BEGIN Layers:=GetLNAME(h); END; END; Procedure Drive_LayerClass; VAR item: LONGINT; data: LONGINT; BEGIN CASE item OF SetupDialogC BEGIN GetLayers; IF Layers=layer THEN SELChoice(a,i,ok); END; OK:=TRUE; END; BEGIN GetSelChoice(a,0,i,Layers); go:=ItemSel(30); dupl:=ItemSel(40); END; END; END; END; RUN(CreateDialog); Edited February 17, 2017 by rebu1985 Quote Link to comment
rebu1985 Posted February 20, 2017 Author Share Posted February 20, 2017 hi guys, I have created my dialog code for copying objects to selected layers. All info which i have found its about copying objects to all layers but i would like to know how to do it if I just wanna duplicate to selected ones. I dont know how the script should be to transfer the info from the dialog to the object. PROCEDURE CreateDialog; VAR result : INTEGER; id : INTEGER; BEGIN id := CreateLayout('Revise Layer Link',TRUE,'ok', 'Cancel'); CreateStaticText(id,4,'Layers:',-1); CreatePulldownMenu(id,5,32); CreateGroupBox(id,6,'Layers Options',TRUE); CreateCheckBox(id,7,'Planta Sótano'); CreateCheckBox(id,8,'Planta Baja'); CreateCheckBox(id,9,'Planta 1'); CreateCheckBox(id,10,'Planta 2'); CreateCheckBox(id,11,'Planta 3'); CreateCheckBox(id,12,'Planta 4'); CreateCheckBox(id,13,'Planta 5'); CreateCheckBox(id,14,'Planta 6'); CreateCheckBox(id,15,'Planta 7'); CreateCheckBox(id,16,'Planta 8'); CreateCheckBox(id,17,'Planta Atico'); CreateCheckBox(id,18,'Planta Cubierta'); SetFirstLayoutItem(id, 4); SetBelowItem (id,4,6,0,0); SetFirstGroupItem(id,6,7); SetBelowItem (id,7,8,0,0); SetBelowItem (id,8,9,0,0); SetBelowItem (id,9,10,0,0); SetBelowItem (id,10,11,0,0); SetBelowItem (id,11,12,0,0); SetBelowItem (id,12,13,0,0); SetBelowItem (id,13,14,0,0); SetBelowItem (id,14,15,0,0); SetBelowItem (id,15,16,0,0); SetBelowItem (id,16,17,0,0); SetBelowItem (id,17,18,0,0); SetBelowItem(id,18,30,0,0); SetBelowItem(id,30,40,0,0); result := RunLayoutDialog(id,NIL) END; RUN (CreateDialog); Quote Link to comment
MullinRJ Posted February 20, 2017 Share Posted February 20, 2017 (edited) Laura, You are going to need to use: CreateListBoxN(dialogID, itemID, widthInCharacters, heightInCharacters, isMultipleSelect); to display your layer names. The last parameter should be TRUE to allow multiple selections. Also, you need to call a procedure to handle your dialog events, i.e., what to do when you click controls: result := RunLayoutDialog(id, DialogHandler); DialogHandler has two parameters: procedure DialogHandler ( var item :Longint; data Longint ); and usually contains a CASE statement to handle the events: case item of ... end; { case } The first item in the CASE is usually: SetupDialogC: begin { setup code goes here ( load your list with layer names ) } { use AddChoice(dialogid, dialogitem#, list_text, list#); } end; The other CASE items will be your dialog control item numbers if needed. For item 1 (OK) in the CASE statement, you can harvest the selected items in your list there. That is, fill a global array variable with your Layer Names based on the selected list items. After your dialog code exits you will use the array to perform your PASTE operation. Raymond Edited February 20, 2017 by MullinRJ Quote Link to comment
MullinRJ Posted February 21, 2017 Share Posted February 21, 2017 (edited) Laura, You'll also need: GetSelectedChoiceInfo(dialogID, componentID :LONGINT; startIndex :INTEGER; VAR SelectedIndex :INTEGER; VAR SelectedChoiceText :STRING); to determine which items are selected. Raymond Edited February 21, 2017 by MullinRJ Quote Link to comment
rebu1985 Posted February 21, 2017 Author Share Posted February 21, 2017 Hi MullinRJ, I have been working on your comments to do my script and i have done this. I still have some mistakes and i guess its about the array function. Could you help me, please? PROCEDURE dialogl_Main; VAR dialog1 : INTEGER; PROCEDURE dialog1_Setup; BEGIN dialog1 := CreateLayout( 'CreateListBox', FALSE, 'OK', 'Cancel' ); CreateListBoxN( dialog1, 4, 30, 10, TRUE ); SetFirstLayoutItem( dialog1, 4 ); END; PROCEDURE Dialog_Handler(VAR item :LONGINT; data :LONGINT); VAR i : INTEGER; nl : INTEGER; layers : DYNARRAY OF STRING; h : HANDLE; BEGIN CASE item OF SetupDialogC: BEGIN AddChoice( dialog1, 4, 'PLANTA 1', 0 ); AddChoice( dialog1, 4, 'PLANTA 2', 0 ); AddChoice( dialog1, 4, 'PLANTA 3', 0 ); END; 1: BEGIN GetSelectedChoiceInfo(dialog1, 4, 1, i, layers); END; 4: BEGIN nl:=NumLayers; Layers:=GetLNAME (h); DoMenuTextByName('Copy', 0); FOR i:=1 TO nl DO BEGIN DoMenuTextByName('Paste In Place', 0); END; END; BEGIN dialog1_Setup; IF RunLayoutDialog(dialog1, Dialog_Handler) = 1 THEN BEGIN END; RUN(dialogl_Main); Quote Link to comment
Pat Stanford Posted February 21, 2017 Share Posted February 21, 2017 I did something like this a few years ago, and I think it was working then. Now the setting of check boxed is not working properly. I was going to find time to fix it and post it, but I know I am not getting to it this week, so here it is in it's broken state. I hope this helps. Use with caution. It appears to continually create duplicate objects and will basically crash VW or bring it to a halt as it sits now. The last time I ran it, I got 21,000,000 million duplicates. ;-) PROCEDURE LB_LayerList; {©2008 Pat Stanford, pat@coviana.com} {Licenses under the LGPL. No Rights Reserved} {Use at your own risk. Code is broken as written} {No warranty or suitability for use expressed or implied} VAR B1:boolean; dialog1 : LongInt; kImageCheck,kImageBlank,kImageSheet,kImageView : Integer; LayerArray : DYNARRAY[] of String; NumLayers, N1, CheckedLayers : Integer; FirstObjectToCopy : Handle; ThisObjectToCopy : Handle; LayerToCopyFrom : Handle; LayerNameToCopyFrom : String; ThisLayer : String; ThisDuplicate : Handle; {-----------------------------------------------------------------------------} FUNCTION GetPlugInString(ndx :INTEGER) :STRING; BEGIN CASE ndx OF {Static Text} 3001: GetPlugInString := 'OK'; 3002: GetPlugInString := 'Cancel'; 3003: GetPlugInString := 'Layers'; END; END; {----------------------------------------------------------------------------} PROCEDURE Dialog_Setup; VAR cnt : INTEGER; BSB : Boolean; BEGIN dialog1 := CreateResizableLayout(GetPlugInString(3003),TRUE,GetPlugInString(3001),GetPlugInString(3002),TRUE,TRUE); CreateLB(dialog1,4,34,15); CreatePushButton(dialog1,5,'All'); CreatePushButton(dialog1,6,'None'); SetFirstLayoutItem(dialog1, 4); SetBelowItem(dialog1,4,5,0,0); SetBelowItem(dialog1,4,6,0,0); SetRightItem(dialog1,5,6,0,0); SetEdgeBinding(dialog1,5,False,False,False,True); SetEdgeBinding(dialog1,6,False,False,False,True); END; {-----------------------------------------------------------------------------} PROCEDURE Dialog_Handler(VAR item :LONGINT; data :LONGINT); Var ColNum,TempI,I : Integer; SheetTypeIcon : Integer; BSB : Boolean; BSS : String; LayerHand : Handle; LayerName,SelectedIconString : String; SheetIconNumber,SelectedIconNumber : Integer; BEGIN CASE item OF SetupDialogC: BEGIN {These need to be declared as globals otherwise they won't work outside of setup.} kImageCheck := AddLBImage(dialog1,4,1,11022); kImageBlank := AddLBImage(dialog1,4,1,11023); kImageSheet := AddLBImage(dialog1,4,1,11024); kImageView := AddLBImage(dialog1,4,1,11025); ColNum := InsertLBColumn(dialog1,4,0,'Copy To',50); BSB := SetLBControlType(dialog1,4,ColNum,3); BSB := SetLBItemDisplayType(dialog1,4,ColNum,1); BSB := SetLBColumnWidth(dialog1,4,0,0,20); {ColNum := InsertLBColumn(dialog1,4,0,'',50);}{This crashes VW} ColNum := InsertLBColumn(dialog1,4,1,'Layer Name',100); BSB := SetLBControlType(dialog1,4,ColNum,1); BSB := SetLBItemDisplayType(dialog1,4,ColNum,3); BSB := SetLBColumnWidth(dialog1,4,1,1,200); ColNum := InsertLBColumnDataItem(dialog1,4,0,'Checked',kImageCheck,-1,0); ColNum := InsertLBColumnDataItem(dialog1,4,0,'UnChecked',kImageBlank,-1,0); {Traversing from LLayer by PrevObj doesn't work with Sheet Layers} LayerHand := FLayer; I := 0; While LayerHand <> NiL do Begin If GetObjectVariableInt(LayerHand,154) = 2 then SheetTypeIcon := kImageSheet else SheetTypeIcon := kImageView; ColNum := InsertLBColumnDataItem(dialog1,4,1,GetLName(LayerHand),SheetTypeIcon,SheetTypeIcon,0); TempI := InsertLBItem (dialog1, 4, I, GetLName(LayerHand)); BSB := SetLBItemUsingColumnDataItem (dialog1, 4, I, 1, ColNum); BSB := SetLBItemUsingColumnDataItem (dialog1, 4, I, 0, 1); I := I+1; LayerHand := NextObj(LayerHand); End; EnableLBColumnLines(dialog1,4,True); END; 1: BEGIN NumLayers:=GetNumLBItems(dialog1,4); CheckedLayers:=0; Allocate LayerArray[1..NumLayers]; For I := 1 to NumLayers do Begin BSB := GetLBItemInfo(dialog1,4,I-1,1,LayerName,SheetIconNumber); BSB := GetLBItemInfo(dialog1,4,I-1,0,SelectedIconString,SelectedIconNumber); If SelectedIconString = 'Checked' then Begin CheckedLayers := CheckedLayers+1; If SheetIconNumber = kImageSheet then LayerArray[CheckedLayers]:=LayerName; If SheetIconNumber = kImageView then LayerArray[CheckedLayers]:=LayerName; End; {If} End; {For} End; {1} 5: Begin For i:=0 to GetNumLBItems(dialog1, 4)Do Begin BSB:=SetLBItemInfo(dialog1,4,i,0,'Checked',kImageCheck); End; {For} End; {5} 6: Begin For I := 0 to GetNumLBItems(dialog1,4) do Begin BSB:=SetLBItemInfo(dialog1,4,i,0,'Unchecked',kImageBlank); end; {For} end; {6} END; {Case} BSB:=RefreshLB(dialog1,4); END; {Procedure} {-----------------------------------------------------------------------------} function ResourceIsOK :BOOLEAN; BEGIN IF SetVSResourceFile('IP Resources') THEN ResourceIsOK := TRUE ELSE Message('The "IP Resources" file was not found.'); END; {-----------------------------------------------------------------------------} BEGIN {Main} FirstObjectToCopy := FSActLayer; LayerToCopyFrom := ActLayer; LayerNameToCopyFrom := GetLName(LayerToCopyFrom); IF ResourceIsOK THEN Dialog_Setup; IF RunLayoutDialog(dialog1,Dialog_Handler) = 1 THEN BEGIN SysBeep; For N1 := 1 to CheckedLayers do Begin ThisLayer:=LayerArray[N1]; If ThisLayer <> LayerNameToCopyFrom Then Begin ThisObjectToCopy := FirstObjectToCopy; While ThisObjectToCopy <> Nil do Begin ThisDuplicate := CreateDuplicateObject(ThisObjectToCopy,GetLayerByName(ThisLayer)); ThisObjectToCopy := NextSObj(ThisObjectToCopy); End; End; {If} End; {For} END; {If} Wait(1); ClrMessage; END; Run(LB_LayerList); Quote Link to comment
MullinRJ Posted February 21, 2017 Share Posted February 21, 2017 Laura, I haven't looked at Pat's code, but he is using a ListBrowser approach. It isn't wrong, but it's a lot more complicated than what you need (IMO). I added comments to your code and commented out pieces that were causing errors. It runs but doesn't do much. I hope this helps. Raymond PROCEDURE dialogl_Main; VAR dialog1 : INTEGER; PROCEDURE dialog1_Setup; BEGIN dialog1 := CreateLayout( 'CreateListBox', FALSE, 'OK', 'Cancel' ); CreateListBoxN( dialog1, 4, 30, 10, TRUE ); SetFirstLayoutItem( dialog1, 4 ); END; { dialog1_Setup } PROCEDURE Dialog_Handler(VAR item :LONGINT; data :LONGINT); VAR i : INTEGER; nl : INTEGER; layers : DYNARRAY OF STRING; { this needs to be GLOBAL or it will be rewritten on each dialog event. } h : HANDLE; BEGIN CASE item OF SetupDialogC: BEGIN { you need a loop here to add your design layer names to the dialog ListBox using AddChoice() } { are these layer names? they are being added to the Layer Name ListBox. } { or is this test data? (which is OK) } AddChoice( dialog1, 4, 'PLANTA 1', 0 ); AddChoice( dialog1, 4, 'PLANTA 2', 0 ); AddChoice( dialog1, 4, 'PLANTA 3', 0 ); END; { SetupDialogC } 1: BEGIN { this only gets one choice starting at the second line (line 1) } { the lines start at "line 0". Not the documentation says this function is "0-based". } { there is no consistency in VS as to what is "0-based" or "1-based". You have to read. } { put this in a loop to get all choices and save the text in your array as you go. } { GetSelectedChoiceInfo(dialog1, 4, 1, i, layers); } { count your design layers and allocate your Layer Name array here. } { then add your choices to it with a loop. } { GetSelectedChoiceInfo() will return -1 when it can't find any more selections } END; { 1 } 4: BEGIN { this code is in the wrong place } { pasting needs to be done in ITEM 1 (at the end) or in the main program after the dialog is done. } { copying needs to be done on SetupDialogC event, or before the dialog code starts. } { item 4 doesn't really need any control. Selection is handled by the ModernDialog machine. } (* nl := NumLayers; Layers := GetLNAME (h); DoMenuTextByName('Copy', 0); FOR i :=1 TO nl DO BEGIN DoMenuTextByName('Paste In Place', 0); *) END; { 4 } END; { case } END; { Dialog_Handler } { this was missing } BEGIN dialog1_Setup; IF (RunLayoutDialog(dialog1, Dialog_Handler) = 1) THEN BEGIN END; { this was missing } END; RUN(dialogl_Main); Quote Link to comment
rebu1985 Posted February 21, 2017 Author Share Posted February 21, 2017 Thanks for your help guys, Finally I got it! I am carry on checking more scripts. I am so addictive now!! I want to learn more and more!! Quote Link to comment
Marcus Brinsden Posted April 17 Share Posted April 17 Thanks for this post guys...Using "GetSelectedChoiceInfo" wasn't as obvious as I first thought! Quote Link to comment
rebu1985 Posted June 14 Author Share Posted June 14 Hi guys, I write you because in a newer version of vectorworks I cant run the scrip properly and I dont know why. I have used Pat´s scrip in VW2015 but in version 2020 I have the problems of selecting the layers, the only option I can do is selecting all/none. Can you help me, guys? PROCEDURE LB_LayerList; VAR B1:boolean; dialog1 : LongInt; kImageCheck,kImageBlank,kImageSheet,kImageView : Integer; LayerArray : DYNARRAY[] of String; NumLayers, N1, CheckedLayers : Integer; FirstObjectToCopy : Handle; ThisObjectToCopy : Handle; LayerToCopyFrom : Handle; LayerNameToCopyFrom : String; ThisLayer : String; ThisDuplicate : Handle; {-----------------------------------------------------------------------------} FUNCTION GetPlugInString(ndx :INTEGER) :STRING; BEGIN CASE ndx OF {Static Text} 3001: GetPlugInString := 'OK'; 3002: GetPlugInString := 'Cancel'; 3003: GetPlugInString := 'Layers'; END; END; {----------------------------------------------------------------------------} PROCEDURE Dialog_Setup; VAR cnt : INTEGER; BSB : Boolean; BEGIN dialog1 := CreateResizableLayout (GetPlugInString(3003),TRUE,GetPlugInString(3001),GetPlugInString(3002),TRUE,TRUE); CreateLB(dialog1,4,34,15); CreatePushButton(dialog1,5,'All'); CreatePushButton(dialog1,6,'None'); SetFirstLayoutItem(dialog1, 4); SetBelowItem(dialog1,4,5,0,0); SetBelowItem(dialog1,4,6,0,0); SetRightItem(dialog1,5,6,0,0); SetEdgeBinding(dialog1,5,False,False,False,True); SetEdgeBinding(dialog1,6,False,False,False,True); END; {-----------------------------------------------------------------------------} PROCEDURE Dialog_Handler(VAR item :LONGINT; data :LONGINT); Var ColNum,TempI,I : Integer; SheetTypeIcon : Integer; BSB : Boolean; BSS : String; LayerHand : Handle; LayerName,SelectedIconString : String; SheetIconNumber,SelectedIconNumber : Integer; BEGIN CASE item OF SetupDialogC: BEGIN {These need to be declared as globals otherwise they won't work outside of setup.} kImageCheck := AddLBImage(dialog1,4,1,11022); kImageBlank := AddLBImage(dialog1,4,1,11023); kImageSheet := AddLBImage(dialog1,4,1,11024); kImageView := AddLBImage(dialog1,4,1,11025); ColNum := InsertLBColumn(dialog1,4,0,'Copy To',50); BSB := SetLBControlType(dialog1,4,ColNum,3); BSB := SetLBItemDisplayType(dialog1,4,ColNum,1); BSB := SetLBColumnWidth(dialog1,4,0,0,20); {ColNum := InsertLBColumn(dialog1,4,0,'',50);}{This crashes VW} ColNum := InsertLBColumn(dialog1,4,1,'Layer Name',100); BSB := SetLBControlType(dialog1,4,ColNum,1); BSB := SetLBItemDisplayType(dialog1,4,ColNum,3); BSB := SetLBColumnWidth(dialog1,4,1,1,200); ColNum := InsertLBColumnDataItem(dialog1,4,0,'Checked',kImageCheck,-1,0); ColNum := InsertLBColumnDataItem(dialog1,4,0,'UnChecked',kImageBlank,-1,0); {Traversing from LLayer by PrevObj doesn't work with Sheet Layers} LayerHand := FLayer; I := 0; While LayerHand <> NiL do Begin If GetObjectVariableInt(LayerHand,154) = 2 then SheetTypeIcon := kImageSheet else SheetTypeIcon := kImageView; ColNum := InsertLBColumnDataItem(dialog1,4,1,GetLName(LayerHand),SheetTypeIcon,SheetTypeIcon,0); TempI := InsertLBItem (dialog1, 4, I, GetLName(LayerHand)); BSB := SetLBItemUsingColumnDataItem (dialog1, 4, I, 1, ColNum); BSB := SetLBItemUsingColumnDataItem (dialog1, 4, I, 0, 1); I := I+1; LayerHand := NextObj(LayerHand); End; EnableLBColumnLines(dialog1,4,True); END; 1: BEGIN NumLayers:=GetNumLBItems(dialog1,4); CheckedLayers:=0; Allocate LayerArray[1..NumLayers]; For I := 1 to NumLayers do Begin BSB := GetLBItemInfo(dialog1,4,I-1,1,LayerName,SheetIconNumber); BSB := GetLBItemInfo(dialog1,4,I-1,0,SelectedIconString,SelectedIconNumber); If SelectedIconString = 'Checked' then Begin CheckedLayers := CheckedLayers+1; If SheetIconNumber = kImageSheet then LayerArray[CheckedLayers]:=LayerName; If SheetIconNumber = kImageView then LayerArray[CheckedLayers]:=LayerName; End; {If} End; {For} End; {1} 5: Begin For i:=0 to GetNumLBItems(dialog1, 4)Do Begin BSB:=SetLBItemInfo(dialog1,4,i,0,'Checked',kImageCheck); End; {For} End; {5} 6: Begin For I := 0 to GetNumLBItems(dialog1,4) do Begin BSB:=SetLBItemInfo(dialog1,4,i,0,'Unchecked',kImageBlank); end; {For} end; {6} END; {Case} BSB:=RefreshLB(dialog1,4); END; {Procedure} {-----------------------------------------------------------------------------} function ResourceIsOK :BOOLEAN; BEGIN IF SetVSResourceFile('IP Resources') THEN ResourceIsOK := TRUE ELSE Message('The "IP Resources" file was not found.'); END; {-----------------------------------------------------------------------------} BEGIN {Main} FirstObjectToCopy := FSActLayer; LayerToCopyFrom := ActLayer; LayerNameToCopyFrom := GetLName(LayerToCopyFrom); IF ResourceIsOK THEN Dialog_Setup; IF RunLayoutDialog(dialog1,Dialog_Handler) = 1 THEN BEGIN SysBeep; For N1 := 1 to CheckedLayers do Begin ThisLayer:=LayerArray[N1]; If ThisLayer <> LayerNameToCopyFrom Then Begin ThisObjectToCopy := FirstObjectToCopy; While ThisObjectToCopy <> Nil do Begin ThisDuplicate := CreateDuplicateObject(ThisObjectToCopy,GetLayerByName(ThisLayer)); ThisObjectToCopy := NextSObj(ThisObjectToCopy); End; End; {If} End; {For} END; {If} Wait(1); ClrMessage; END; Run(LB_LayerList); Quote Link to comment
Jesse Cogswell Posted June 14 Share Posted June 14 @rebu1985 The reason the script no longer works is because the AddLBImage function was made obsolete in 2012. The new function is AddListBrowserImage which takes in a file path for the icon image rather than using an internal index. The advantage is that it allows you to use custom icons. The disadvantage is you now have to know the file path for the standard icon images, which does not appear in any appendix or function reference that I know of (but I would be very interested to see). You can get the script working by replacing lines 68-71 with: kImageCheck := AddListBrowserImage(dialog1,4,'Vectorworks/Standard Images/Checkmark.png'); kImageBlank := AddListBrowserImage(dialog1,4,'Vectorworks/Standard Images/Blank.png'); kImageSheet := AddListBrowserImage(dialog1,4,'Vectorworks/Standard Images/[Sheet Layer Icon Name]'); kImageView := AddListBrowserImage(dialog1,4,'Vectorworks/Standard Images/[Design Layer Icon Name]'); Unfortunately, I do not know the icon names for Design Layers or Sheet Layers, so you'll have to figure that out (unless someone here knows offhand). For now, you can comment out those lines and the rest of the script will run just fine. If someone has a Mac, the process for extracting icons is listed here under the heading Use icons from Vectorworks.app. Placing the name where I have the bracketed text will cause the correct icon to be loaded in with the layer name. 1 Quote Link to comment
Pat Stanford Posted June 14 Share Posted June 14 Layers.png SheetLayers.png Thanks @Jesse Cogswell 1 Quote Link to comment
Jesse Cogswell Posted June 14 Share Posted June 14 Of course! I tried Layer.png and SheetLayer.png and several combinations of things with that, but didn't think to make it plural. Quote Link to comment
rebu1985 Posted June 15 Author Share Posted June 15 Thanks guys, now it is working. 🙂 Quote Link to comment
