alfresco Posted February 11, 2017 Share Posted February 11, 2017 I have created a Polygon, used clip surface and created an extrude. I want to model a vanity with counter with a cut out for a sink. I am unable to crete an auto hybrid? I am not sure why, but I get an error message referring to a poly break with the name auto hybrid already exists in document? Why can I not create an auto hybrid? thanks, lm Quote Link to comment
AlanW Posted February 11, 2017 Share Posted February 11, 2017 @alfresco Hi can you post a file for us to look at please. Quote Link to comment
bcd Posted February 12, 2017 Share Posted February 12, 2017 (edited) Do a search, you probably have named something (a polyline?) Auto Hybrid elsewhere in your file. VW typically only allows a name to be used once in a file. Edited February 12, 2017 by bcd Quote Link to comment
joerg Posted February 14, 2017 Share Posted February 14, 2017 it's a bit off topic but i would be carefull with Autohybrits as it slows down the grafic performance... at least for me. I allways work arround by creating a 2D/3D symbol or a floor object .... Quote Link to comment
bcd Posted February 14, 2017 Share Posted February 14, 2017 (edited) A lot of folks use a Floor or Slab object for a simple counter with cut-out. You can Add/Subtract 3d Objects to achieve the required edge details. Edited February 14, 2017 by bcd 1 Quote Link to comment
AlanW Posted February 14, 2017 Share Posted February 14, 2017 (edited) Hi, I work with a lot of Autohybrids where its not possible to use other means and I don't find it slows things down. The benefit is to using Autohybrids when modeling in 3d saves huge amounts of time. Draw once and you can get the dotted over the section, the top plan and elevations all from one object. If you set it up correctly. I like the thinking above with the slab. See attached file of a pergola and look at the viewports and the settings for the Hybrid. HTH Auto Hybrid Pergola v2017.vwx Edited February 14, 2017 by Alan Woodwell Quote Link to comment
alfresco Posted February 18, 2017 Author Share Posted February 18, 2017 chatwinensuite2017.vwx Hello File attached. If you find any problems... thanks for all your assistance! chatwinensuite2017.vwx Quote Link to comment
AlanW Posted February 18, 2017 Share Posted February 18, 2017 (edited) @alfrescoHi, Attached is your file. the issue as to why you were unable to create a Hybrid was a corrupt wall. I have highlighted it in blue. Delete this off your file and autohybrid works. I will run a video about this because it was good to go over a file and think about the way I would set things up, starting from unit setup to wall penetrations. HTH and I will set a link to the video. The other thing i forgot to mention was you will notice 3 classes for Auto hybrid ansd look at the settings . Refer to my channel Alan Woodwell in youtube for the video about Autohybrids to help you understand it better. chatwinensuite2017_(1).zip Edited February 18, 2017 by Alan Woodwell Quote Link to comment
alfresco Posted February 18, 2017 Author Share Posted February 18, 2017 Allan, Thank you very much for your time and assistance. I was unable to establish the cause for the auto hybrid failure. This is a very good learning experience and I will review the material posted. Greatly appreciated! lm Quote Link to comment
AlanW Posted February 18, 2017 Share Posted February 18, 2017 (edited) @alfrescoHi, Did you delete the wall that I said was causing you to be unable to create the Auto Hybrid. Not sure why this was the issue but it fixed it.??? @JimWTry this, the vertical wall was taken out of the other file and I found this to be the cause for the error in creating an auto hybrid, try to make an auto hybrid. Fail. (on my PC) Why?? Untitled1.vwx Edited February 20, 2017 by Alan Woodwell Quote Link to comment
alfresco Posted February 22, 2017 Author Share Posted February 22, 2017 Once the corrupt wall was deleted the auto hybrid worked as expected. Thanks for all the help! lm Quote Link to comment
