paulg
Rendered perspective plan?
I am trying to create a rendered cut section viewport but in 'plan' orientation.  Is this possible?
My model is in one layer, its a small pavilion and I want to try placing the section cut at different heights, in order to pick up different features.
Any tips would be gratefully received.
Paul
Create a Viewport on a Sheet Layer in Front View
Select it and View>Create Section Viewport  - draw your section line stepping with each click to define the pararallel cut planes.
Here is a couple of samples for clinic floor plan. One one the perspective is set to normal but the rendering technique is a combination of white model style (background) and hidden line (front). Second sample, I personally like it more for presentation purposes a bit more contrast, no lines.
Edited by Luis M Ruiz
Strange, when I try this as a straight (not stepped) section, I get the option to render in perspective. But if I step it, I don't. What am I missing?
Too many steps - it seems like VW can handle non-orthogonal projections for 1 step (2 plane) Section Viewports only.
Edited by bcd
15 hours ago, bcd said:
I like.
This would be great as a WebView default.
Since that look is from Renderworks and not live like OpenGL, the engine would have to render every possible angle and view during export. So if one view in that render mode took 15min to render and you needed 256,000 possible viewpoints or more... the math hits you in the face quite hard.
We plan to improve WebView appearance but it wont be Renderworks quality anytime soon.
could we not have a clip cube whilst creating a camera view on a design layer just pull the clip to create your desired view and then export as a viewport
On 2/9/2017 at 10:33 AM, JimW said:
We plan to improve WebView appearance ..
This is very welcome Jim. Currently as a proof of concept it's very encouraging but the outputs are generally not client-ready.
Would it not be possible to Render the scene with a RenderStyle and bake those pixels into surfaces of the WebView model - something like a bitmap overlay. Currently afaik a rendering will render every  pixel on every surface whether on not it's visible in the scene so presumably the information is already there?
This is what I asked the engineers and got a range of responses from cringing to pensive scowls, not that they didn't think it would be a good addition, but more that it is apparently way more complex to implement than that. I suspect we will get 360 panoramic realistic renders before the same concept could be brought in to webview.
at least the pensive engineers were thinking.
It would be kind of like a dense point cloud in reverse, render once fly through at will.
I suspect it will happen, a lot of different features are going that direction in a lot of modeling software. Inevitable but just not super soon.
(Related note: I recently had the chance to use an HTC Vive to look around the inside of a scanned interior point cloud in VR. It was veeeeery strange, but cool. Like standing inside an old memory or maybe a memory made after a bit too much drinking. )
EDIT: This is close to the example I saw:
Yes, those points need to web together so we don't feel like we're exploring a hologram
working with a tech company at the moment and though web 3D could be good but after trying I do agree not client ready. My fear is in current form it's going to set things back not move them forward.
Now being able to render a static lighting set up to a nice dense point cloud could be far more presentable.
