Hole Pattern Tool.... Problem
RussU
Hi everyone.
I'm experiencing issues with the hole pattern tool.
It works fine when your hole type  is set to "round", but when you go to "slotted horizontal", you're unable to change the slot width... Slot length is fine, but slot width just throws out your changes.
Only way to put in a value is to change the hole type to round, put in a new diameter and then change back to "slotted horizontal". Bit annoying as it slows you down quite a lot.
VW 2017 Designer, SP2
Win 8.1
3 answers to this question
Posted (edited)
Bump! This bug is still buggin' in VW 2021 sp3
The workaround:
Set the hole size to your desired smallest dimension before changing from holes to slots. The other dimension is now editable.
Convert back to holes to adjust the smallest value.
Edited by fuberator
