Gabriel Chan
Visualization palette and object info palette conflict
Hi all,
Referring to the attachment, we can see that the Class value of Channel 71 is "SET-Garden mat", whilst the object info palette displays the correct Class value "Lighting-Fixtures".
Attempting to change the class value again in the OIP does not alter the Class value in the Visualisation palette, but changes in the Layer value in the OIP are correctly reflected in the visualisation palette.
Possible bug?
Gabriel
12 answers to this question
You are not alone with this. It seems that a lighting instrument holds its insertion class in the visualisation palette making it nigh on impossible to change.
It would be great to know if there is a way to fix this.
Could you send me that file or post a sampling from it? A new test file here didn't have the issue but with spotlight objects it's best to test the originals since the connections with hanging positions/accessories etc can also be factors.
Nope, I was able to replicate it immediately and no those two fields should always report the same class name value regardless of how you have things configured. Submitting this now, thank you.
Hi, I am currently expierencing this problem and am wondering if there is a fix or workaround for this? A collegue has instrument that where once placed in the active class and remain in that class in the Visualization Palette.
I did a quick check in 2020sp2 and it looks like it's still an issue. I could not find the issue in our system for this specific problem so I created one so we can take a look at the problem. You can reference VB-166672 is you have any further information to add the the issue.
@klinzey thank you for filing the issue again!
