Sheet list worksheet - extra rows?
jwouie
I created a worksheet to use as a sheet index, pulling info from my sheet borders/titleblocks.
The worksheet pulls several extra blank rows and I can't figure out how to get rid of them. Screenshot attached. I'm confused because there are 12 sheets and the header of row 2 correctly indicates 12. But there are 22 rows? How can I get rid of these? Messing around with adding a Criteria, it looks like I have 22 sheet borders, 12 of which have the right record attached. How do I find those extra 10 and get rid of them? I couldn't figure out how to use the Criteria to do it.....
Thanks.
1 answer to this question
Edit the criteria of the database to only look at the layers where you have actual sheet border objects.
VW considers each instance on a layer AND in a viewport when doing the counts.
So if you have borders on 12 Design layer and 10 Viewports that are also showing the images, you will get a count of 22.
Ask again if I have not been clear.
