Stephan Moenninghoff 386 Posted January 24, 2017 Could the slider be modified to accept its min, max and default values from input ports? Let's assume I wanted to set the amount of an element in a list by slider. In that case I would need to get the list length for its maximum and default values. If anyone can help me I would be most grateful. I promise to learn Python one day. All this Marionette wiring is keeping me off it, I guess :-). Quote Share this post Link to post
Marissa Farrell 464 Posted January 24, 2017 Unfortunately at this time, this isn't possible. There's no way to define an OIP control dynamically. It's definitely on our list of things to try to improve, but we so far haven't made any headway. OIP controls must be statically defined. Quote Share this post Link to post
Marissa Farrell 464 Posted January 24, 2017 I will follow up with this idea though - you could use the slider node to define a percentage of a range of values, or even a factor, it just would not directly reflect in the OIP. Quote Share this post Link to post
Stephan Moenninghoff 386 Posted January 24, 2017 Yes, that's what I'm doing now. It works well enough for what I'm trying to do. Thanks for confirming though! Quote Share this post Link to post
