Kevin McAllister
Creating a Loft while inside a Group - Preview Fails
I am seeing some preview issues when creating a loft while inside a group. If I'm in wireframe the preview of the loft fails completely (some lines flash and disappear when I press the preview button) or if I'm in OpenGL I get an unfilled wireframe preview. Working outside a group the loft previews as expected in both wireframe and OpenGL. Can someone else confirm this? Is this a known issue?
(I often use groups to isolate elements for editing in a complex model and many actions that create NURBS also group them....)
Kevin
4 answers to this question
Hi, Kevin - Confirmed all.  Good catch!
Same results for me in combos of several contexts (Attributes set to solid color fill):
•Ortho & Normal Perspective
•OGL, Wireframe (even some fqrw)
•Flyover, Top, Top Plan
While testing grouped and ungrouped, I included a planar object with fill and a 3d surface with fill to indicate whether the view is rendered or wire frame.
Same results every context:
•If elements are not grouped, the preview is a lofted surface with color fill (OGL) or a wireframe (WF "render").
•Inside a group, the wireframe preview causes flashes, but no preview.
•Inside a group, OGL produces a preview with the parametric (?) lines but no color fill
-B
