christian Posted November 20, 2003 Share Posted November 20, 2003 Is there any way to open a ClarisCAD document in VW10.5? Thanks, Christian Quote Link to comment
RGyori Posted November 20, 2003 Share Posted November 20, 2003 To my knowledge it involves a 3 step process. First, you need the application Claris CAD Translator known as "CC2MC 1.7" which will translate into MiniCAD. (Two cautions: shorten long CC file names and make sure the CC drawing scale has been set using the first scale button or the translation will likely fail). Then you need to open the MiniCAD document in VW 8 and save it as a VW 8 document. The resultant document can then be opened using VW 10.5. This process has worked for me in the past. I'm not sure if CC2MC 1.7 is still available so if you can't find it let me know at RGyoriArch@aol.com and I can send it to you. Good luck! Robert Gyori Quote Link to comment
