gavin2604 Posted January 19, 2017 Share Posted January 19, 2017 Hi, I am currently working towards PAS1192:2-2013 mandate and I am having some issues with the IFC import and the way we create windows. As we work on large housing schemes we work with window types, a method Vectorworks have previously advised to do it. So we create windows and then turn into symbols, so when placed within a wall they appear as a 'symbol in the wall'. However when exporting to IFC and either re-importing into VW to test or into Solibre Model Checker, the IFC format does not acknowledge the relationship between the wall and the window. I therefore tried exploding the symbol to test if it was this and when it is a 'window in wall' it views fine. I was wondering if anyone has had a similar issue and a work around. One way i was going to try was using symbol geometry in the window settings. therefore if you change the original source component then this will still change. However this will result in manual window changes to each window for height width etc. I have attached a solider model checker screenshot showing the if import result of a door in a wall as a 'symbol in a wall'. This also applies to doors. Thank you. Gavin Quote Link to comment
bcd Posted February 11, 2017 Share Posted February 11, 2017 HI Gavin, Rather than placing the symbol in the wall directly use the Window tool to place a window in the wall and select your Window Type symbol as for its source. Note, VW 2017 Window and Door Styles make this unnecessary when dealing with windows and doors that can be drawn sufficiently using the PIO itself. Quote Link to comment
BLAM Posted February 23, 2017 Share Posted February 23, 2017 Window and Door Styles in VW2017 fixes this problem now Quote Link to comment
ardee Posted February 28, 2018 Share Posted February 28, 2018 Hi, I'm having this problem using window styles with Vectorworks 2018. What is more concerning is that the same window style have different IFC outcome in Solibri. Most windows do not show their relationship with the wall... Any ideas? Quote Link to comment
Vectorworks, Inc Employee JuanCarlos Posted February 28, 2018 Vectorworks, Inc Employee Share Posted February 28, 2018 Have to ask – Are all windows inserted in walls? If yes, could you send me a file with the wall and windows you are showing, for testing. Thank you Quote Link to comment
ardee Posted March 1, 2018 Share Posted March 1, 2018 (edited) 13 hours ago, JuanCarlos said: Have to ask – Are all windows inserted in walls? If yes, could you send me a file with the wall and windows you are showing, for testing. Thank you Yes all windows are inserted in walls. The issue with windows disappear when exported as 2x3 'simplified geometry' but most of our custom 3D objects are dislocated/misplaced all over the place... files attached. Solibri_test_ardee.vwx Edited March 1, 2018 by ardee Quote Link to comment
Vectorworks, Inc Employee JuanCarlos Posted March 1, 2018 Vectorworks, Inc Employee Share Posted March 1, 2018 For the dislocated objects, attach the Ifc entity before you group them, if you have multiple objects with different Ifc entities use from the AEC dropdown menu "IFC Zones, Systems and Groups..." to create any of these. As for the windows, the window is there, the frame cuts the wall the glass doesn't, reinserting it and flipping it some times fixes it, I will write a bug for it. HTH Quote Link to comment
ardee Posted March 2, 2018 Share Posted March 2, 2018 Thank you Juan, it did help a lot. All extrusions and groups are in the right place now. As you said IFC tags must be given to the objects not to the groups... Cheers! Quote Link to comment
zoomer Posted March 2, 2018 Share Posted March 2, 2018 On 1.3.2018 at 6:39 PM, JuanCarlos said: For the dislocated objects, attach the Ifc entity before you group them, if you have multiple objects with different Ifc entities use from the AEC dropdown menu "IFC Zones, Systems and Groups..." to create any of these. I tried similar with Symbols. Does it work different there ? Have some furniture Symbols that contain some Extrudes. (Everything on same Class, ....) To be sure I assigned IFC_Furniture to all Extrudes AND the Symbol. No it seems I have each furniture piece as a separate object. No more grouping by the Symbol. Should I assign the IFC Tag to the Symbol only if it contains IFC Object of same Type only, or also use "IFC Zones, Systems and Groups..." for the Symbol ? Quote Link to comment
Vectorworks, Inc Employee JuanCarlos Posted March 3, 2018 Vectorworks, Inc Employee Share Posted March 3, 2018 For Symbols attach the Ifc entity directly to the symbol through the Resource Manager HTH Quote Link to comment
zoomer Posted March 4, 2018 Share Posted March 4, 2018 Thanks Juan Carlos, ok, so from now on I will assign IFC Tags to the Symbol only, no more additional to its content. Quote Link to comment
Henrique Lauer Posted February 9, 2021 Share Posted February 9, 2021 Hi, I´m having some problems exporting custom symbols by IFC. First of all, when i create datasheet custom fields, they don´t appear when a try to use it with a custom symbol. Second, all my custom symbols don't appear in my model at Solibri. Have anyone trouble with custom symbols and IFC data? It´s driving me crazy 😬 Quote Link to comment
Vectorworks, Inc Employee JuanCarlos Posted June 9, 2021 Vectorworks, Inc Employee Share Posted June 9, 2021 Hi Henrique, You have to attach the IFC record to the symbol at the Resource level (Right click on the Symbol), in you case would be IfcFurnishingElementType then mark/check the IFC entities/Psets that are to be used and fill the Property Values as desired HTH 1 Quote Link to comment
Henrique Lauer Posted June 9, 2021 Share Posted June 9, 2021 Hi JuanCarlos, thanks I used to attach IFC data by Resource Manager. After this, i used to put those symbols on my model. So, i have been realized wich when i create customs data, some symbols doesn´t appear in this customs property. I believe wich this is a bug, isn´t? Quote Link to comment
Vectorworks, Inc Employee JuanCarlos Posted June 9, 2021 Vectorworks, Inc Employee Share Posted June 9, 2021 Can you send me a file with an object that behaves properly or close and one that doesn't and list some parameters that you like to see Quote Link to comment
