Records and worksheets
when you want to show any kind of record field in a database row, this is the structure you should use:
=RECORDNAME.FIELDNAME
In case the record or field name contains spaces, you need to add ".
="RECORDNAME"."FIELDNAME"
In case of a parametric object, the default record has the same name has the object. In your case you need to use the name of your custom record.
