VerhoevenJ
Records and worksheets
I have made a symbol and attached a record. In this record I have made a field where you can give a length and a drop down menu that has 4 options.
Now I want to make a worksheet that gives me the sum of the length fields with the specific option selected in the drop down menu.
Can anyone help me?
Worksheet_&_records.vwx
Edited by VerhoevenJ
Share this post
Link to post
when you want to show any kind of record field in a database row, this is the structure you should use:
=RECORDNAME.FIELDNAME
In case the record or field name contains spaces, you need to add ".
="RECORDNAME"."FIELDNAME"
In case of a parametric object, the default record has the same name has the object. In your case you need to use the name of your custom record.
Share this post
Link to post
Wait...does 2017 have drop-down menus in record formats???  I might have to retry it this week and see if it's stable for me now!  That was one of my biggest wishlist items, and I didn't even realize it.
Share this post
Link to post
I thought earlier versions as well. You can create a list of possible values that can appear in the drop down.
Share this post
Link to post
If there's a way to do that in record formats in 2016 and prior, I've never found it.  I can do it within Spotlight fields.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
