Greycat Posted January 14, 2017 Share Posted January 14, 2017 I've just upgraded from VW12 to VW17. I am creating a 3D model, but I can't seem to make the colored axes disappear when I render the model. Since many most renderings don't have the axes, I'm sure there must be a simple toggle switch to turn off the axes, but I can't find it. Any suggestions? Thank you. Quote Link to comment
zoomer Posted January 14, 2017 Share Posted January 14, 2017 I think it is hidden in snapping settings. Could be some rests in VW Preferences though ... Quote Link to comment
Pat Stanford Posted January 14, 2017 Share Posted January 14, 2017 There is an option in Grid Snapping to show or not show the Z axis. Double Click any of the icons in the Snapping Palette to get the dialog box and then choose Grid in the left column. Look at the box in the lower right. I don't know of a way to hide the other axes, but I expect that it exists somewhere. 2 Quote Link to comment
Benson Shaw Posted January 16, 2017 Share Posted January 16, 2017 (edited) Some things to consider/try: •Clip cube displays xyz axes when it is turned on and the cube boundary is selected in the drawing. Check Clip Cube status View Menu near bottom. If check mark shows, then the Clip Cube is on. Click to uncheck. •Vectorworks Prefs> Display Tab> Colored axes in Top/Plan view. Disable that pref. •Axes are displayed when a working plane is enabled, including a temporary one established with the Working Plane Tool and a custom one invoked from the Working Plane Palette. There may be some other ways the axes would display in the drawing area I'm not thinking of. If the axes and pink rectangle are on, one way to switch them off is to enable the Working Plane Palette (Menu Bar>Window>Palettes>tic the Working Plane item to display the palette) then dbl click the Active Layer Plane item in the palette to remove display of the xyz axes and pink rectangle. -B Edited January 16, 2017 by Benson Shaw blabbiddy balb blab Quote Link to comment
Vectorworks, Inc Employee Luis M Ruiz Posted January 16, 2017 Vectorworks, Inc Employee Share Posted January 16, 2017 Keep in mind that if you are doing final renders then make use of sheets and viewports and do not rely on just screenshots from layers. Quote Link to comment
Benson Shaw Posted January 17, 2017 Share Posted January 17, 2017 Another way to defeat the axes during Design Layer rendering is to render using the Render Bitmap tool in the Visualization tool set. Set parameters in the mode bar prefs button, then drag a marquee around desired view area. The render will proceed and a bitmap will be created right on the drawing. Move/Cut/Paste to other software or otherwise manipulate the bitmap as needed. -B Quote Link to comment
Greycat Posted January 19, 2017 Author Share Posted January 19, 2017 Thank you, all! I used the "double click on grid snapping" method and got what I was looking for. M Quote Link to comment
ashot Posted December 1, 2017 Share Posted December 1, 2017 Tools > Smart Cursor Settings > Grid > Show 3D Axis (uncheck) 1 Quote Link to comment
ashot Posted September 5, 2021 Share Posted September 5, 2021 For "double click on grid snapping" method Uncheck "Show 3D Grid Axes" 1 Quote Link to comment
3D frustrations Posted October 18, 2023 Share Posted October 18, 2023 In the Vectorworks preferences go to "Interactive appearance settings" and turn the grid and smart cursor planes to zero opacity. That seems to get rid of it. It also gets rid of the red and green lines in editing modes. Quote Link to comment
