Some Custom Input Nodes
The Attached Vectorworks Document contains the following Marionette Nodes:
1. "GetNextObject" --> Put This in a Wrapper with another Object. This node Returns the next Object (Stacking Ordner) after this node
2. "PageBased_mm" --> Will return a Page Based mm value. Handy to create Page Based Objects
3. "InputCode" --> Allows to simply enter math operations or any other python code via the input field
4. "AttachUnit" --> Recursive (Supports nested List or Tuples) Node which multiply every number in the input node with a document unit based factor.
5. "Color" --> Input Node to Return RGB Value of the Node's color.
A short movie documentation is available:
https://youtu.be/KZ5-nqP_1wo
Input Node Collection.vwx
