x references became all ghosted after reopening file
KateatBrehm
Hi All,
I am using ref files in a drawing. I closed the file and after reopening it today have found all of the ref files are ghosted. We have figured out that the refs were on the none layer and the none class has disappeared and currently the refs do not exist on any layer. Does anyone know how to fix this?
Thanks in advance.
Edited by KateatBrehm
It is not possible to remove the "None" class.  You should send your file to tech support if you don't see "None" in your class list, something is broken.  If your externally referenced files are red on the list, that means that they can't be found, either because they were moved or were created in a different version of VW.
