VW-PAD-Bristol-2014 Posted January 10, 2017 Share Posted January 10, 2017 Hello, I was wondering whether anybody else has been having issues with design layer/reference viewports after converting 2016 to 2017. We have a set of drawings where the crop is not working. As we zoom in we can see the other objects outside of the crop. (see screen grab) This happens whether we are using the existing crop or a new crop. I have tried using different classes etc.. but this doesn't seem to help. If you have any ideas it would be gratefully appreciated. Many Thanks James Quote Link to comment
0 JMR Posted February 7, 2017 Share Posted February 7, 2017 We have the exact same problem. Try turning off unified view, if you can work without it being turned on. This solved the problem for us. Quote Link to comment
0 VW-PAD-Bristol-2014 Posted March 17, 2017 Author Share Posted March 17, 2017 Hi JMW, Thanks for this. We also found that changing the "navigation graphics" in the display tab of Vectorworks preferences to "good performance and compatibility" seems to work too. Just another work around. Quote Link to comment
0 JMR Posted April 4, 2017 Share Posted April 4, 2017 Thank you for the tip. I confirm that for us as well, the issue was solved by changing the display performance setting to the middle setting. Quote Link to comment
VW-PAD-Bristol-2014
Hello,
Many Thanks
James
3 answers to this question
