  • 2
This topic was originally introduced in General thread by pclary, December 29, 2016.
Redo of topic here for bug verification.
Fastener placement on working planes is problematic - Working As Designed?  Bugs?  Graphics card related? Or?
Summary:
If a custom working plane is activated via the Working Plane Palette, and then a 3d mode of any fastener tool is enabled via the Fastener Tool Set, then:
1. The custom working plane is deactivated on screen and the Working Plane Palette item changes to have a gray background.
2. vwx creates a new, temporary working plane (ie this new plane does not manifest in the Working Plane Palette).
• This new working plane is parallel to the Layer Plane
• This new working plane has same origin as the former custom working plane.
3. The custom working plane can be reactivated while the tool is active:
• dbl click on the desired custom item in the WP Palette.
• The tool will now place a fastener object on the custom working plane.
4. Except a Special Case:
• The Fastener Tool in 3d mode (1st tool in the tool set) always places the fastener object with origin and axis on the layer plane.  Tool apparently cannot place a fastener origin and axis on any plane other than the Layer Plane.
• Automatic Plane is not available when Fastener Tool 3d mode is active.
Demo video:
https://vimeo.com/197646616
-B
1 answer to this question
I would think that when using a tool with an expressly 3D mode, that tool should acknowledge 3D working planes. There looks to have been a very old bug on this item, I'll check that and resubmit if need be.
VB-45230
