Samuel Derenboim Posted December 20, 2016 Share Posted December 20, 2016 Good afternoon everyone, This is more of a wish list item more than anything. Dealing with different engineers that work in autocad, i find it a bit frustrating to export elevations with hatches in BIM mode to be converted into linework. More importantly, when selecting option for hatches to be converted to a separate layer, any exported elevation (not plans) hatches in vectorworks aren't converted to a different layer, instead they remain in the original layer of the wall type class. As a result the dwg files become bloated and hard to modify. Any way to change this? I know a workaround, however, its a bit cumbersome - which essentially converts any surface into a poly - that can use hatch information. This exports just fine into required hatches, just a nuissance to do for every job. Perhaps there is another way? Thanks in advance !! 1 Quote Link to comment
rDesign Posted December 20, 2016 Share Posted December 20, 2016 I find this to be a real pain as well, especially if you use a hatch made up of a bunch of short lines like 'sand' or 'plaster'. When you export to DWG / DXF you'll get a million short lines that you have to delete, including on elevations which are perpendicular to the VP camera. Because of this I have started to turn off surface hatches before I export to DWG. IMO, the current SVLP -> DWG Export workflow leaves much to be desired. Quote Link to comment
