Alex T Posted December 19, 2016 Share Posted December 19, 2016 Hi all, I am slowly learning Vectorworks after using AutoCAD for many years, and I'm having problems creating lighting positions in the program. I've created several electrics using the lighting pipe tool, but whenever I try to convert them into lighting positions in the Spotlight menu, the "Convert to Light Position" tool is greyed out and unusable. Any insight/settings I could have wrong that could be causing this? Quote Link to comment
markdd Posted December 19, 2016 Share Posted December 19, 2016 Can you include the file so I could take look? Quote Link to comment
Alex T Posted December 19, 2016 Author Share Posted December 19, 2016 Sure, I have attached it. I imported it from an AutoCAD file, so some of it is a bit messy, but ignore the layers such as "???" that are irrelevant. It is still all a work in progress, so some remaining pieces from CAD still remain. WEEPAC_VWX.vwx Quote Link to comment
markdd Posted December 20, 2016 Share Posted December 20, 2016 The drawing opened in Top view. You need to be in Top/Plan for the command to work. I hope that works for you! Mark Quote Link to comment
