Bruce Kieffer Posted October 25, 2003 Share Posted October 25, 2003 Is there a way to organize layers and sheets similar to the hierarchy organizing available with classes? Quote Link to comment
Bruce Kieffer Posted October 31, 2003 Author Share Posted October 31, 2003 I'd appreciate it if someone could give me an answer on this. Quote Link to comment
Alexandre Villares Posted October 31, 2003 Share Posted October 31, 2003 Do you mean like the sub-menu behavior you get when you name a Class like 'name-subname-thirdname'? No there is no such thing for Layers, perhaps because they represent a different organising idea: They are not alphabeticaly sorted like classes so you can change their order using the up/down/bot/top buttons at the Layers panel. Quote Link to comment
MikeB Posted October 31, 2003 Share Posted October 31, 2003 Alexandre is right, Layers and classes are very different organizational tools. Layers are used for placing objects in space, where one layer is above or below another where Classses are used for identifing what an object is but not where it is. Sort of like if the objects we create were animals the Layer is the habitate the animal lives in and the Class would be the species. Good Luck Quote Link to comment
Bruce Kieffer Posted October 31, 2003 Author Share Posted October 31, 2003 OK, so that's it for layers. How about organizing sheets? Anyway to do get them organized like can do with classes? I make detailed drawings where I need to turn classes and layers off just so I can make sense of what's going on. Navigating to theses views can be really slow. Sheets help a lot, but I can have 30 plus sheets in some drawings, and that gets confusing too. It would be great if sheets could be placed in folders that then "pop-open" when you roll over the folders name in the sheets pop-up list in the lower tools section of the VW window. Quote Link to comment
Guest Posted November 3, 2003 Share Posted November 3, 2003 You can't do that with sheets. Sheets are just listed. There is not way to classify them. Quote Link to comment
Vectorworks, Inc Employee Andrew Bell@NV Posted November 3, 2003 Vectorworks, Inc Employee Share Posted November 3, 2003 quote: Originally posted by Katie: You can't do that with sheets. Sheets are just listed. There is not way to classify them. Right, Katie, but I think the suggestion is that NNA provide a nesting mechanism as is done for classes. Since sheets don't have an order issue like layers do, this could be accomplished via the same technique; one dash (or perhaps two) would indicate a base name and a sub-name, and all sheets with the same base name should show up as sub-menu elements off of the base name. It's certainly a sensible suggestion. Quote Link to comment
