sww1235
Auto Hybrid Help
Hello:
I have used the extrude along path tool to create a custom curved builtin bookshelf, however on top/plan view it is not showing up with my chosen fill.
I found this thread about converting it to an auto-hybrid, however none of the settings I have found in the auto-hybrid settings, allow me to use the fill in top/plan view like my wall objects.
I would assume there is something small but important I am missing.
Thanks in advance
After you set up your auto hybrid style at the bottom save the current settings as the default and always keep the 3 classes I every template file. Now whenever you create on it automatically assigns these classes. If sometimes you find you can't change the appearance of an item in a viewport that is on a certain class and it's an auto hybrid you may need to change the auto hybrid and not the class the object is on when adjusting through a viewport.
