walls not staying joined
Using VW 10: whenever I copy a floor plan- the walls of the copied and orginal plan are no longer joined together, but disconnected- I have to go back and join them together- every time I make copy- any one know what the problem might be-is there some preference or button I need to push?
I figured out my problem- I believe it is related to the VW 10- enable connected walls mode- I used to put a marquee around a group of walls- duplicate and move into place- apparently this is no longer an option-
one person told me to put a marquee around the walls and then use duplicate array- seems a little more cumbersome- but I'm getting used to that-
does anyone know of a better way- and could the connected walls mode feature be disabled in the next version? please?
