Hi,
I'm creating a staircase with the Stair Tool but I'm encountering problems with the second stage of treads. From TOP/PLAN the staircase appears all straight and lined up. But when seen from TOP the second stage of treads appears slightly crooked. It's a tiny bit but the treads are not truly at 90 degrees. Maybe there is something wrong with my settings... but I don't think so. Also I get a weird set of circular lines... (this is not as bad of a problem as the treads are)
I think the problem occurs when I set the STAIR LANDING CORNERS radius.
I leave a set of screenshots that explain the problem.
TOP:PLAN view.png
%22parallel%22 lines in TOP:PLAN View.png
11 answers to this question
Ok, I see it too.
Increasing Offset 1+2 does not help.
But setting the landing rounding just a bit smaller as the max. possible number (like 0,148 instead of 0,15)
makes the upper treads orthogonal again.
I would say this is a bug.
Don't know why the Meshing is so bad and if there could be any improvements.
Edited by zoomer
It did it initially in Top but now seems to be straight in both. If I reload the file I see the crooked line but then upon any draw or object regen it corrects itself. However it isn't file specific, if I create a Stair with similar settings I can recreate the crookedness intermittently, I'll pass this along to see if someone can nail it down.
