  • 3
bcd
Landscape Area that shows 2d plants
9 answers to this question
Yes, please!
Otherwise, update/change the thumbnails of Object Styles because It's currently misleading in Resource Manager. The user tries a lot to get that presentation which is NOT possible.
I am also trying to display 2D plant symbols in the landscape area and would expect this to be a default option. VW, please make this possible.
All,
For your information I wrote Tamsin Slatter directly about this issue and sent a link to user BCD's original post. This was her reply:
"Thanks for your message. I was discussing this very topic with the developers at HQ just yesterday, so your question is timely. It's not possible to display the individual plants within the landscape area I'm afraid. The only way to show 2D plants is to use the Plant tool, but, of course, that doesn't give you the mix.
We did discuss the possibility of including this in a future release (no promises at this stage). One question that then popped up though... if you COULD see the 2D plants, would that then lead to you wanting to be able to move them around within the Landscape Area? Or would you be content with the placement that the tool gives you?
Regarding the placement of the tags, I have recently filed this as a bug/enhancement request. It is being worked on, but again, I'm afraid I can't give any timescale on that.
I hope that helps."
I am all with you guys - that would be really useful to be able to show the specimens within the groups in the Top/ Plan view.
@SurroundingsCS , what did you respond to @Tamsin Slatter eventually?
Personally, when I propose planting groups, I tend to specify that the contractor plants the same species in groups of 3-7 specimens. I am not a programmer, but if such a behaviour could be at least optional it would be brilliant!
What are your thoughts?
@Michal Zarzecki,
This what I wrote back to Tamsin on June 14, 2019:
"In the hypothetical scenario where 2D plants could be displayed having the versatility to move the plants within the landscape area would be preferred. But simply having 2D plants displayed without the capability of moving them would still be very helpful."
She replied on June 14, 2019:
"Thanks. I'll pass this back to the team."
We show individual plant objects at Design Development and unless I can control the placement of the plants within that landscape area, the tool is useless beyond Schematic Design. Maybe if enough users pressure them for this feature we could see it in 2020? I hope this helps.
That the landscape areas are NOT showing the individual plants is actually a request which came from Landmark users. It's an extra step put in just because designers didn't want the individual plants visible - they wanted clean, large areas without the fuzziness of all the plants.
However, we have received this request before and it is put in as an enhancement request.
@Katarina Ollikainen, thanks for getting involved in the conversation.
I can clearly understand where this might have come from. In our work for example, for large residential or school projects with limited budget and time constraints, we don't have the time for showing each specimen on our plans - we tend to show areas of single or mixed-species.
However, I think it would be great if there was a choice - similar to the one we have with the 3D representation.
I will watch this space to see where this will take us.
Regards,
MZ
Vectorwork users
One way to get around this limitation, is to create a copy of landscape with mixed planting and place it just above the previous one. Now select the copy and ungroup it. This will show 2D component of plant and the landscape area underneath will keep all the landscape settings safe.
For Vectorworks
Its very easy to enhance Landscape feature. Like you have programme coding for Hardscape area in which one can choose 2D components (attribute) and 3D component (texture), the same algorithm in programming can be used to create Landscape which will have both 2D and 3D component of plants.
