Tom Klaber Posted December 13, 2016 Share Posted December 13, 2016 It is really annoying that None is buried in the class list alphabetically. Can we rename it '0' so it sits on top? Or maybe we can introduce Pinned Classes - special classes that sit on top of the main list? Quote Link to comment
0 zoomer Posted December 14, 2016 Share Posted December 14, 2016 For me alphabetic order is the most important thing to make me find my things again. I'm totally irritated in cases where it is not available. So that is where I look for and expect my None Class to be, between M and O. For me the None Class is quite visible as it is the only Class that has only 4 letters, everything else has far more and the None Class looks like a break. I never use Classes Hierarchy option anywhere because it is so much harder to view or to select. Back to your question, I also think there could be some improvements in these lists. The first is the ability to apply a text Background Color, which helps a lot for recognition. The next is the ability of a tree structure with subfolders, but by drag and drop and not by changing Class Names. And still alphabetically sorted. And of course some Filtering and Search Bar, like "Wood" will only show Classes containing the term "Wood". Quote Link to comment
0 Tom Klaber Posted December 14, 2016 Author Share Posted December 14, 2016 While I agree - generally alphabetically is best - 'None" is special - and I need special access to it. We can easily have 100 classes in a document, and None is too important to simply be buried in there. So allowing "Pinning" would allow me to pin to top, and Zoomer to leave it alphabetically. Another solution maybe would be colors - allow me to color the name in the Navigation Pallet so it is red. - Though I think I would use colors for other reasons - and once everything has a color - this again would make it hard to find. Maybe a live search? Start typing and the best class is activated? - Probably a bad idea. I think renaming "0" might be the best way to go....except for the whole changing fundamental VW conventions. Quote Link to comment
0 zoomer Posted December 14, 2016 Share Posted December 14, 2016 I need the 0_prefix to sort other special Classes Nothing against a pinning feature. I just proposed my thoughts to the discussion. I have that color thing in Modo, just 2 hand full of colors available but I have seen no problems when all Items are colored. That is what I usually do. It still nicely separates and groups things into there ... ahm ... classifications. I think your "live search" is what I am used in Modo, C4D, .... you activate the loupe symbol and as soon as you start to type letters in the field, it will hide everything that does not contain that letter or finally word(s). If you use some proper Class Naming, you can isolate things of interest by an order that is not given by Class Naming itself. Like searching for "concrete" will you sort all Wall-concrete, Column-concrete, ... in a row, like to apply IFC cost tags to the materials, although that order does not exist in Classes or Layers. Quote Link to comment
0 Tom Klaber Posted December 14, 2016 Author Share Posted December 14, 2016 1 hour ago, zoomer said: I think your "live search" is what I am used in Modo, C4D, .... you activate the loupe symbol and as soon as you start to type letters in the field, it will hide everything that does not contain that letter or finally word(s). Yes! Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted December 14, 2016 Vectorworks, Inc Employee Share Posted December 14, 2016 The quicksearch is a must in my opinion. Since they don't require complex database checks or image previews, it could be made to work even faster than the Resource Manager and not require the user to even hit Enter, just slim down the search as the user types. I had put in a request for that as well as a system for custom-sorting (I never specified pinning but that makes good sense) the class or layer list, the Organization dialogue and subsequently the Navigation palette could do with quite a bit of refresh that I think every user would be pleased with and wouldn't disrupt anything. 3 Quote Link to comment
0 bcd Posted February 9, 2017 Share Posted February 9, 2017 On 12/13/2016 at 3:02 PM, Tom Klaber said: It is really annoying that None is buried in the class list alphabetically. Can we rename it '0' so it sits on top? Turns out YES. I'm floored. Quote Link to comment
0 bcd Posted February 9, 2017 Share Posted February 9, 2017 But new objects that use None will create a None class automatically. - Class mapping for all? Quote Link to comment
0 Matt Overton Posted February 10, 2017 Share Posted February 10, 2017 Pining None and say the half a dozen of the most recent user selected classes at the top of list could be very handy. Like it is with other very long lists like Fonts. Quote Link to comment
Tom Klaber
9 answers to this question
