floor tileing
tringas1
I usually create my own textures using an image. IN this case o photoshopped a tile & a bit of grass on 2 sides then used it as the image to create the texture. the one on left is without displacement, the one on the right needs mowing and the far right one is 2d using the same image and using surface array form VW. Prob need to adjust the image to your scale.
HTH
Tile_&_Grass.vwx
