MRD Mark Ridgewell
VW2017 skirting, architrave, coving, cornicing, trims
Looking for the best way of drawing the above. Using 'interior elevation viewports' I tend to draw the lines in annotation which is fine, but must be an easier way. Have used 'extrude along path' previously for decorative profiles which works well but is fiddly around doors.
Is there away of utilizing wall tool for these profiles?
Hi Jim
the video you linked to does not really cover some of the issues with the EAP method and also the skirting that was added is in the wrong place as it is half-way into the floor.
If you draw the path with say the polyline tool then its important to know which way you drew it: clockwise or anti-clockwise as you will get different results. In the images attached both examples look the same but the the left path was cw and the right path was anti cw. The results are different and therefore you have to handle the profile edit differently. This catches a lot of people out.
Also the video overlooked Lock Profile Plane which takes away the pain of having to edit the profile after the EAP (so much easier)
Yeah some of the older videos were less thought out, the ones I work on I try to be a little more thorough in ;)
Useful links for extrude along path..
I guess I was wondering if there's a way to add profiles using wall tool, so the profile cuts automatically, so a bit like a wall does when you insert a door? For use for example in a corridor with lots of doors (20+). Maybe one for a future vw release!
In its basic form, EAP definitely is one of the most unfriendly commands in VW. Its desire to centre the profile on the path is at the root of this. It would be infinitely better if the user could select the profile origin during creation or if a symbol, which has its own definable origin, could be used for the profile. EAP is essentially a pipe tool being used for molding :-)
The future of molding creation more likely lies with Marionette, which is able to overcome some of these issues and create a more user friendly experience.
Kevin
Kevin
Even better would be the ability to insert a 2D symbol into a Wall Style and be able to bind it to a Level so that it could be used as a wall base, crown molding, etc that would move with the wall and automatically be cut by doors or windows.
Edited by rDesign
  • Like 3
Probably true for architects..... I don't use the wall object that much in my work but I do use a lot of moldings.
KM
I'm in the Marionette camp for a short term solution but firmly in the Make Walls Do This camp for the long term. I can see why the Feature In Wall was added so that volumetric data/IFC stuff would be accurate, but making users manually create geometry that should just be: "This is always a part of this component when used on any wall" like the caps mentioned here:
There are a lot of good reasons for a profile-based-follow-the-walls-path elements to be included in our Wall objects. I have a wish in for that, I'll add this thread to it.
I find I can use a Marionette Object to do the work and I have cut out the fiddly aspect of the process.
See video as to how to use it and use file attached.
HTH
House_001A_v2017.vwx
Another option is the framing member tool, you can use custom profiles , is parametric so you don't get all those 'extrude along path' lines in plan view, does a mitred joint neatly. Bit more work involved than EAP but can be quicker for later alterations.
they really need to update door tool with custom architrave profile option.
