  • 4
Tom Klaber
Updating All Callouts From Updated Database
How do I update all notes with new wording from the database?
I figured that if I use the database, then it would coordinate the notes - so if a specification or phrasing needed to change - I could make the change once - then all affected notes would be updated.  But it seems I still need to go around to each not individually and update it - which is hardly better than copying and pasting.
Am I missing something?
  • Like 4
13 answers to this question
I'd like this confirmed too.  We use Keynotes from a database, and unless we're using them wrong, once the keynote is placed, it is no longer linked to the database. If the keynote description changes, we have to update the database to match.  We think it should work so that the keynotes are always linked to the database.
Yes - or at least you would have the option to "Link Note To Database" or not - so that some notes could be customized per instance, while others stay linked.
Did this ever happen? I can't find the option to re-link to database changes?
I also added a request to the functionality today... simply to have an optional tick box in the object info palette to display only the database description, not all the notes.
No.
My understanding is that the database and the notes are not linked.  Once a note is placed - it is its own entity.
So you can create a database of standard notes - but changing the phrasing or specification of a note will not affect previously placed notes.  unfortunately.
Shame. Undermines the point of a database, I mean, may as well copy/base from a word document otherwise.
Thanks for reply
Have you tried the reconcile notes tool? Not quite what you are after but might help. I've just started playing with it recently and haven't quite got the hang of it yet but it will pick up unlinked callouts which you can then update to or from a database.
@BG
Could I ask what data base editor you use for this? I'm trying notepad xml 2007. Its ok, but it seems if you change the section or note titles in the XML editor, they are lost the next time you edit/save the notes from VW?
Thanks
Hi
We don't open the database directly, but edit it using the Notes Manager within the callout tool.  From what I understand, the database is formatted very specifically and you would have to be very careful not to mess up the specific formatting to ensure it still works correctly.
Hello @BG
You are right about the formating, so I thought I would post an update on progress regarding notes, data bases and work flows. Anyone who finds this helpful, you have my brother to thank for this. Sadly I'm not a VB coder.
Attached is a text file with a script written in Visual basic for excel. It allows you to use excel to drive your Vectorworks notes database, where by it runs an export from an excel file, creating:
-    The A column becomes the description,
-    The B column becomes the notes (main text content).
Tabs become different sections, but as yet it just names them -1, -2,-3 etc, and these need to be changed within VW. But we are looking to resolve this.
This means as a team you can use excel to edit, and input into a central data set (and use all the notes and track changes included in this).
For those of you using NBS, its possible to export into excel using a few methods, then with some simple editing you can have your NBS references etc as notes (NBS used to make a tool to do this, but it stopped working with VW 2016 I think. There was little uptake on it, so NBS stopped supporting it)
How to use.
You need excel. Maybe it works in google sheets, I’ve not tried it yet but I will.
-    First turn on the developer tab. Do this via File>options>customise ribbon, and tick the developer tab.
-    Then open the visual basic editor (far left on my version)
-    Then click inset > module
-    Copy and paste the contents of the text file into here.
-    goto tools >> references and scroll down and tick "Microsoft scripting runtime" to include the libraries that you need
-    No need to save anything. Just close the VB editor.
Every time you want to run the macro, go to the developer tab, click on macros (second left on my version), then run the macro called export. This will save a .xml file where you choose. From VW, go to database controls > choose > click the exported xml, and… all your data is now in the VW database😀
Obviously, we are taking no responsibility for messing up excel files/data files. But all the above worked well for me. I’ll post up if we get the tab naming thing working.
Here are some more detailed notes about the code and external data base control, if you are using them…
The long random strings in the example files are GUIDs which are unique identifiers that are used by databases to identify objects.
Usually they are automatically created whenever you add a new entry to a database table.
If you are importing your xml to create new items in the CAD database it probably doesn’t expect to be given guids - it will create its own as it creates each object from the xml entries
However, reading the documentation it looks like they can be used by the CAD software to synchronise between its objects and those in an external database (or excel etc) and it’s own items. In which case they may be needed.
There is a flag at the top of the code to turn on and off the ability to generate guids in the xml when it creates the file depending on whether the cad software needs them or not. Change to true or false (with in the code in the module) to export with or without guids.
Also note that it will generate a new guid for each item every time you export the file. If you intend to use the xml to sync or update entries then you don’t want it to create new guids every time - it will likely create duplicate entries in the cad data - instead it will need to use existing guids and will need some slightly different code to this.
ExportToXML2.txt
It is possible using a database worksheet to do global edits of callouts/keynotes. Not sure how reliable this method is however. Here is a new thread;
