Josh NZ 19 Posted December 7, 2016 In VW2016 the leader line on the callout notes would snap to various angles as per the snapping pallete. This is not working in VW2017. Have tested with line work, text etc and they are all snapping to say 15° increments as set. Is this a bug or is there another setting that has to be enabled for this to work... Quote Share this post Link to post
RGyori 45 Posted December 7, 2016 I suspect this is working as designed though it can be annoying when precise placement is needed. Unselect the snap to angle constraint in the Snapping Palette and it should eliminate the 15º constraint. Quote Share this post Link to post
Josh NZ 19 Posted December 8, 2016 Hmm im hoping its a bug haha. Trying to get the line with arrow to be either 0° or 30°, however won't let me hold shift and draw straight. The angle in the blue box as seen in attached image doesn't seem to relate to anything useful. In the image the angle reads 41°, this isnt from horizontal, im guessing its from the original angle, which if unknown is not much use. Quote Share this post Link to post
knickers 0 Posted January 23, 2017 BUMP! Did this bug/ feature get resolved? It is starting to bug me! Cheers, Nick Quote Share this post Link to post
PVA - Jim 2,382 Posted January 23, 2017 I can't replicate this behavior in 2017 Sp2, however I do not see a logged bug for it either. When I set the Angles from Axis to 15deg it seems to obey that and gives me each increment at 15. Quote Share this post Link to post
Bret 10 Posted May 17, 2017 Just popped in to report that I've seen this issue from time to time, but that it comes and goes. I have never figured out what toggles the setting, but frustratingly, it seems to have toggled again this morning. It has occurred for me a few times even prior to VW2017, and it seems related to this report from 2014 which describes the same issue (or one very similar). As you can can see in the attached screenshots, my leader snap angles are now relative to the tip of the leader, not the shoulder point. #2 is what I get after detoggling the "Angles relative to prior segment" setting. If there's anything that can be done to reset this and prevent it from ever happening again, I'd love to know what it is. Thanks! Quote Share this post Link to post
AlanW 520 Posted May 17, 2017 Just on leader lines I only noticed recently that you can have multiple leader lines from the same note. Right click and you see the command, just keep clicking to add more and you can delete also. Quote Share this post Link to post
Bret 10 Posted May 17, 2017 (edited) The multiple leader topic seems unrelated. That said, I tried it as an experiment and discovered something interesting - for supplemental added leader lines, the snap point becomes the (0,0) page origin. That definitely doesn't seem right. (5/25/2017 Update: When I use "Add Leader Line" today, it doesn't snap to anything, whether I hold down Shift or change my Snap to Angle settings. If I create more than one additional leader all at once, the first one doesn't snap at all and then each subsequent one snaps to the previously picked point. This is different and seems less wrong than snapping to the origin, but it still doesn't seem right.) Edited May 25, 2017 by Bret Quote Share this post Link to post
Bret 10 Posted May 25, 2017 I haven't figured out how to toggle this off, and it's becoming quite an annoyance while trying to get some detailing done this morning. @JimW, is there anything I can do or send in which might be helpful in figuring out what's going on? Quote Share this post Link to post
PVA - Jim 2,382 Posted May 25, 2017 37 minutes ago, Bret said: I haven't figured out how to toggle this off, and it's becoming quite an annoyance while trying to get some detailing done this morning. @JimW, is there anything I can do or send in which might be helpful in figuring out what's going on? If its happening right now or you can replicate it reliably, tech@vectorworks.net is your best bet, they will likely ask for the file as well as the below from your machine: Quote Share this post Link to post
Bret 10 Posted May 25, 2017 Thanks, @JimW. It's not file-specific, so I'll run a dxdiag and e-mail tech support with a description (and link to this thread). Quote Share this post Link to post
