mjm Posted December 2, 2016 Share Posted December 2, 2016 VW 2017 SP Latest, all fresh symbols from VW Object Styles Lighting Instruments, ie: no legacy fixtures When creating instrument summaries for an event, I have succeeded in placing 5 out of 19 summaries. No further summaries seem to be creating. See first MOV. I saved, shut down VW and restarted to no avail. There's also something skippy going on with the tool - see second Mov. thanks all. Inst_Sum_FAIL.mov Inst_Sum_FAIL2.mov Quote Link to comment
markdd Posted December 2, 2016 Share Posted December 2, 2016 I had this problem once and found the only way to sort it out was to remake the lighting position object - Very dull. As a workaround, you could duplicate another position summary and change the filter options and rename in etc..... I've found that quite a useful workflow from time to time Mark Quote Link to comment
mjm Posted December 2, 2016 Author Share Posted December 2, 2016 (edited) 3 minutes ago, markdd said: I had this problem once and found the only way to sort it out was to remake the lighting position object - Very dull. As a workaround, you could duplicate another position summary and change the filter options and rename in etc..... I've found that quite a useful workflow from time to time Mark Gotta tell ya; nothing like a workaround to an intractable problem popping up in one's inbox over lunch. Super! Thanks Mark. Edited December 2, 2016 by mjm Poor penmanship Quote Link to comment
