  • 1
Crash SP2: Align and distribute item tool with Lighting Devices
LamperDave
4 answers to this question
Start by closing Vectorworks if it is open.
I was having the same issue and when I contacted Tech Support today this is what Alexander said. (I would post the plug in but that file extension is not allowed)
He was very quick with the email response containing the modified plug in attached and my Align and Distribute bug is now fixed!
Thank You Alexander!
Quote
"Go to the following location on your machine:
(On Mac) > /Applications/Vectorworks 2017/Plug-Ins
(On Windows) > C:\Program Files\Vectorworks 2017\Plug-Ins
In this location, you will need to delete the following file:
Align and Distribute Items.vst
You will find a new copy of this plugin attached. Once the other one is deleted, place the new attached copy into your plugins folder, launch Vectorworks, and the issue should be fixed. This issue will hopefully be in SP3, but for now the revised plug-in will work.
Thank you"
ALEXANDER SAGATOV
TECHNICAL SUPPORT SPECIALIST
