Josh NZ 19 Posted November 25, 2016 Any ideas on why this is happening. Quote Share this post Link to post
Josh NZ 19 Posted November 25, 2016 Haha, that would fit in with the news here lately. Quote Share this post Link to post
Jonathan Pickup 283 Posted November 25, 2016 I have seen that and I don't think there is anything you can do. You might try removing a couple of the source data points to see if that has an effect. But really i thing you should submit that as a bug Quote Share this post Link to post
MartynHowes 2 Posted August 16, 2017 Hi Josh. Did you get a fix for this issue? I have created 3 site models recently that have all had this same problem. It's a little frustrating Quote Share this post Link to post
Josh NZ 19 Posted August 21, 2017 Hi there, nah no fix unfortunately, we were lucky enough on the particular site, it was so big that we were able to basically not show the whole site and use a small crop. Quote Share this post Link to post
Benson Shaw 574 Posted August 21, 2017 (edited) OK, I have a "fix" workaround. It's same problem as the clipped or bridged contours. The surface mesh is connecting points that should not be connected. Solution is similar, but inconvenient. I tried to induce the problem by making a crop with enclosed areas. Basics: Make a copy of the 2d crop object and paste it on a design layer. Use the split tool in point mode to isolate a section of the poly around/near the problem area(s) Offset this segment of the poly to outside of crop by a small distance. I used about .25 of minor contour interval. Offset to the inside doesn't seem to solve the bridging. Send to surface. This seems to work even on the cropped version of the site model, but if needed, send to surface of an uncropped version of the site model. This creates a group containing a 3d poly (or maybe several 3d polys). Ungroup (or Edit the Group), and Copy the resulting 3d poly(s). Enter the Edit Site Model Source Data. Paste in Place into the Site Model Source Data. Exit the source data space. Update the site model. Note that if the site model was moved x,y from creation location, the edit crop and source data spaces retain the original positions. Some guide objects may be needed to align the pasted objects. OK, probably needs refinement. -B Edited August 21, 2017 by Benson Shaw revised the image & text 2 Quote Share this post Link to post
