kiwi Posted September 30, 2003 Share Posted September 30, 2003 I use a vs to generate files (DXF format) that includes some arcs. The DXF file suppose to be cut by plotter-cuter: but some of the arcs do so the wrong way around! Then, I try to import the same file on Autocad, and the direction (start to end) is the inverse of my vs drawing? Next draw is an "arc" with a polyline: the export will be cut (or import in autocad) correctly. Last I hand draw two sets of arcs face to face with opposite directions, and one set will be export correctly, a bit if any arc will be export on only one angular direction! I'm not sure what to think. My old 8.2 VW never had the problem, and I'm not familiar reading DXF text format to see where's the problem. I hope anyone has an idea of where could be my error: is driving our plotters a bit crazy and makes our cutting inconsistent Dual 1,25 OSX 10.2 and plenty of ram. Thanks for any help! Kiwi. Quote Link to comment
