Framing Drawings - Textures, Tips & Techniques
Taproot
  • 4 weeks later...
Some really good ideas.  I've struggled with posts.  Used the column tool, extruded rectangles, and wall tool.  Never tried a floor object however.  Seems like VW could provide a solution.  Same with "I" joists, can't believe VW does not provide.
Question; how do you do mudsills?  An extrude, a wall or some other method?
I usually do an extrude along path for the mudsill.  Reshaping a poly when things change tends to be simpler than dealing with a whole bunch of short walls.
28 minutes ago, rDesign said:
@Taproot- thank you for sharing your workflow insights and sample files! Some really great tips.
I'm glad that you found the information helpful.
