Josh NZ Posted November 22, 2016 Share Posted November 22, 2016 I have set up a slab style as shown in the below image. As you can see in the offsets have set the lower 3 to have a -200 offset so that I can draw conc blocks around perimeter. The style has worked fine for most applications. Have a growing need to the -200 offset to 3/4 sides with no offset to 1/4 side (Basically where the slab is adjacent an existing structure). Is there a trick to get the object to show offsets to selected sides only or is this a case of having to use a work around. Thank in advance. Quote Link to comment
Josh NZ Posted November 30, 2016 Author Share Posted November 30, 2016 (edited) Found how to perform in VW2017. See from about 44:00 Edited November 30, 2016 by Josh NZ Quote Link to comment
