Tom Klaber Posted November 17, 2016 Share Posted November 17, 2016 I have confirmed this in multiple files. Dimensions lose the ability to be modified in show snap modify others. I can change the length - but depth. See video. 2 Quote Link to comment
0 Vectorworks, Inc Employee Vectorworks - Admin Posted November 22, 2016 Vectorworks, Inc Employee Share Posted November 22, 2016 This should be fixed as of 2017 SP2. Let me know if it does not seem to be. Quote Link to comment
0 Vectorworks, Inc Employee Vectorworks - Admin Posted November 17, 2016 Vectorworks, Inc Employee Share Posted November 17, 2016 Does this happen for you even in a blank file with just a dimension object drawn? Quote Link to comment
0 Tom Klaber Posted November 17, 2016 Author Share Posted November 17, 2016 Yes. It took a little clicking around for it to "Kick In." But I have replicated it in 3 files, including a brand new empty one. So - you need to have more at least 2 layers both at the same scale both set to visible for it to work. So if the other layer is on Grey or Not Visible - the bug is not there, but once I set them both to visible both at the same scale and then click between them once - I then loose control when in Show Snap Modify Others. 1 Quote Link to comment
0 Vectorworks, Inc Employee Vectorworks - Admin Posted November 17, 2016 Vectorworks, Inc Employee Share Posted November 17, 2016 Got it, thank you, confirmed. Couldn't get it initially but after some poking like you suggested it popped up and then kept happening. Submitted as a bug: VB-137850 Quote Link to comment
0 RGyori Posted November 17, 2016 Share Posted November 17, 2016 (edited) Hello Jim, I too have come across the problem and can confirmTom's findings using a new blank VW 2017 document. Oops... to slow on the send click! Edited November 17, 2016 by RGyori 1 Quote Link to comment
0 markdd Posted November 17, 2016 Share Posted November 17, 2016 Tom is right. Replicated the behaviour here as well. 1 Quote Link to comment
0 Vectorworks, Inc Employee Vectorworks - Admin Posted November 21, 2016 Vectorworks, Inc Employee Share Posted November 21, 2016 This is scheduled to be fixed very shortly. Quote Link to comment
0 Tom Klaber Posted November 22, 2016 Author Share Posted November 22, 2016 1 minute ago, JimW said: This should be fixed as of 2017 SP2. Let me know if it does not seem to be. Thanks. Quote Link to comment
Tom Klaber
8 answers to this question
