3D objects have no fill
Erick Thomas
1 answer to this question
What display mode do you use for your 3D view ?
Wireframe will display lines only, no fills.
It should be OpenGL.
If you hadn't, you can set the default view mode in VW preferences that appears when
you switch from Top Plan View to a 3D View. (I have set mine to OpenGL)
If you already had, there are some problems with new 2017 OpenGL Mode.
If there are things not updating on screen or missing, try to go down with the settings
in VW preferences from Best Performance one step down or even to Best Compatibility.
