Is there an easy way to create a Sheet Layer List?
Try this script. Copy everything in the code block below.  Go to the Resource Manager and Create a New Resource of type Script. You will probably need to name both the Script Palette and Script. Paste the script code into the Script Editor window. Make sure it is set to be Vectorscript and click OK.
Double click on the script in the Script Palette to run it.
Procedure SheetLayers_to_Worksheet;
{Make a worksheet listing all of the sheet layers in a VW file}
{Lists both used and unused layers}
{The worksheet is named "Layers:"with and appended date}
{Sorts layers in alphabetical order prior to storing in worksheet}
{November 17, 2017}
{Based on a script originally written}
{March 19, 2015}
{ copyright 2017,2015,2010, 2008, Pat Stanford pat@coviana.com}
{Licensed under the GNU Lesser General Public License}
var	H1, H2:	Handle;
N1, N2:	LongInt;
LayerSort : Array[1..1024] of string;
Begin
	H2:=FLayer;
	N2:=1;
	While H2 <> nil do
		Begin
			If GetObjectVariableInt(H2,154)= 2 then
				Begin
					LayerSort[N2]:=GetLName(H2);
					N2:= N2 + 1;
				End;
			H2:=NextLayer(H2);
		End;
{Add Curly Braces (comment out) the next line to not sort the layers by name}
	SortArray(LayerSort,N2-1,0);
	H1:=CreateWS(Concat('Layers:',date(2,1)),N2,2);
	For N1:= 1 to  N2-1 do SetWSCellFormula(H1,N1+1,1,N1+1,1,LayerSort[N1]);
	SetWSCellFormula(H1,1,1,1,1,'Layers in File');
	ShowWS(H1,True);
End;
Run(SheetLayers_to_Worksheet);
  • 9 months later...
  • 3 years later...
Try this.  You got lucky I didn't want to do real work on a Friday afternoon.  ;-)
{November 17, 2017}
{March 19, 2015}
{November 6, 2020  - Modified to include Sheet Name as well as Sheet Number}
{ copyright 2020, 2017,2015,2010, 2008, Pat Stanford pat@coviana.com}
Type
	PTS = Structure
	  LayerNum, LayerName :String;
	End;
var	H1, H2:	Handle;
N1, N2:	LongInt;
LayerSort : Array[1..1024] of PTS;
Begin
	H2:=FLayer;
	N2:=1;
	While H2 <> nil do
		Begin
				Begin
					LayerSort[N2].LayerNum:=GetLName(H2);
					LayerSort[N2].LayerName:=GetObjectVariableString(H2,162);
					N2:= N2 + 1;
				End;
			H2:=NextLayer(H2);
		End;
	SortArray(LayerSort,N2-1,1);
		Begin
			SetWSCellFormula(H1,N1+1,1,N1+1,1,LayerSort[N1].LayerNum);
			SetWSCellFormula(H1,N1+1,2,N1+1,2,LayerSort[N1].Layername);
		End;
	ShowWS(H1,True);
End;
  • 2 months later...
