Antoine D'Halluin
VW2017 Attributes Palette window resizing bug
Hello,
   when I resize the attribute palette ; it crop a part of the palette simultaneously as it resize the text and the boxes (seems to be proportional). then you have no access to the hidden part of the palette. I cannot scroll up or down.
  for example, I have reduced the size of the palette from the top ; then it has cropped a part of the top. and then I tried to increase the lowest part ; it just generated some white part bellow the palette. see picture joined.
   Is it linked to my config ? to Mac Os config ? to some config error in my VW config ?
thanks
PS I am using VW2017 on Mac OS 10.11.6.
3 answers to this question
Does it return to normal when you increase the width? If not then you may want to file a support request as increasing the vertical palette size from the bottom should return the vertical part back to normal.
I am unable to replicate this here in 2017 SP1, when I re-expand the palette after crushing it all of the controls reappear.
Hello,
thanks for your answers. No, resizing the width did not make the other element to reappear. even playing with top and lower limit doesn't make all visible
after checking a lot of element, I finally joined the palette to another palette and then, I got top bar reappear (the one with the expand and the close button) & the palette to resize.
I cannot replicate the bug & I don't know really what I did to get in this situation sorry. but I can note some parameters of my config if it helps to replicate... let me know
kind regards
