Design Layer Referencing – Storey Level Stair Glitch
Diamond
Hi,
Any idea to get around this?
When I reference design layers that are set up to use Storeys and  Storey Levels, Stair objects (set to Storey levels in the referenced file) break, and I get a red cross in a rectangle. To get around this problem. I have to override the stair object to take their height 'By Value' and not by 'Layer Elevation'.
Is there anyway I can fix objects within referenced design layers and level heights attached to Storeys? Thanks.
5 answers to this question
8 hours ago, zoomer said:
If I remember correctly I had the same with Walls.
So that nothing in DLVP will adopt to Story Levels. Is this correct ?
Yes. Objects will adopt the base story heights, but not intermediate storey levels.
But the reason I don't want to use DLVPs is because when I create section VPs of the DLVP, and render in Hidden line, due to some bug, I cannot override the line weights of objects beyond the section plane.O.o
Edited by Diamond
Ok, you reference the old way, whole geometry.
And this works for Level assignments except for the stairs ?
Then there could be a way to fix the Stairs behaviour.
Or just the only objects that have Levels assigned.
Can you set Stairs to Layer height -x.xx to get the Level height if it works for Layer heights ?
Hope someone has an idea.
